SOURCE: Manual for the NSM Prestige E160 and circuit for 76M amplifier
If you send me your details I will scan my circuit diagram for the 76M amplifier. I do not have the manual but I do have a list of the programing locations.
Regards
Alan Hood
ami-man
UK
[email protected]
SOURCE: how do I slow the speed of the 45s on my rowe
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
SOURCE: I have an old NSM Prestige 120 jukebox which
are you sure you dont have it in test mode because this allows it to play for about 20 secs only on each selection
SOURCE: i have a nsm prestige 120 jukebox which plays but
try putting another tape or cd player into the audio ports on the board if they dont give any sound then its down to the amp you can run the service programmes that may tell you
SOURCE: i have a nsm nostalgia gold jukebox that won't play a cd with a err 73
error 73=check alignment of cd gripper
Testimonial: "how do you check the alignment of cd gripper"
