Question about Gateway (COOLINGFAN) for Solo 1100 Laptop Cooler
Gateway MX6421 Laptop Keyboard replacement
How do I remove and replace the entire keyboard on a Gateway MX6421?
Great solution, take it somewhere to pay someone to fix it.
Posted on Dec 27, 2007
  • 42 Answers
Hi
I have two alternatives to solving your problem the first is if your PC is still under warranty have the store replace the said keyboard and everything will be fine failing that the only other solution is to take it to a reputable store for them to fix it for you hope this is of any help
Posted on Nov 05, 2007
How do I replace a keyboard on a Gateway NE522?
Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg
Replace Keyboard Gateway Laptop or
Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
5.November.2015
Nov 05, 2015 | Gateway Computers & Internet
Replace lcd on mx6421
Use the link below to chat with a technical person of gateway who can assist you in replacing the lcd on a gateway
Chat with Gateway
Jul 01, 2008 | Gateway MX6421 Notebook
Replace keyboard
The service manual (in pdf format) for the Gateway MC7833u (which I believe is also applicable for the MC7803u, in case the model was listed incorrectly) details the procedure for removal and installation of the keyboard. Get it here: http://support.gateway.com/s/Manuals/Mobile/8512949.pdf
Sorry, you'll have to copy and paste the url, I couldn't make the entire thing hotlinked.
The procedure you're looking for is detailed on pages 7 and 8... but keep that manual somewhere handy (NOT on your main drive - I'd recommend keeping it in the cloud so you can access it when/if your laptop experiences technical difficulties), as it's difficult to find and it'll come in all kinds of useful.
Hope that helped!
Nov 29, 2013 | Gateway MC7833U Notebook PC
How do I replace the keyboard on a Gateway LT3119U?
Visit the Gateway support document website and locate the "User's Guide" section of the listings for your laptop model.
You should be able to locate either a "component replacement manual," or a document focusing specifically on replacement of the keyboard for that model (as different models of keyboards have slightly different methods of removing the keyboard.)
You may also wish to check the FAQ's in the support documents of your model, as they may also contain information on replacing the keyboard.
Power down your Gateway laptop and remove the battery.
This will not only ensure that you don't accidentally damage your laptop by powering it up while working on its components, but may also be necessary to reach the mounting screws for your laptop's keyboard.
Press the power button once after the battery has been removed to discharge any remaining electricity that the laptop may have stored.
Consult the support documents for your Gateway laptop model and find out where the keyboard mounting screws are located.
There will most likely be between two and five screws, depending on the specific model of laptop that you own.
You may be required to remove the keyboard bezel (the strip of plastic that runs along the top of the keyboard) in order to reach some or all of the screws; this can be done either by sliding the bezel off to the right of the laptop or by simply lifting it off once loosened (though you may need to use a coin or flat-head screwdriver to detach clips or pry the bezel out of its resting location.)
Remove the screws holding the keyboard in place.
The screws will either be located on the bottom of the laptop (under the space that the battery occupies) or beneath the keyboard bezel.
Put the screws in a safe place where they will not be lost, since you will need to use them to secure the new keyboard.
Lift the keyboard up from the bottom, detaching the keyboard connector and pulling the keyboard itself free from the Gateway laptop, then setting it aside.
You may need to once again use a coin or flat-head screwdriver in order to depress clips which might be holding the keyboard in place.)
Plug your new keyboard into the keyboard connector, then carefully place it back into the space previously occupied by your old keyboard.
If the keyboard is designed to be held in place by clips, press down with sufficient pressure to clip the keyboard into place.
Replace the screws that you had previously removed from the Gateway laptop.
Make sure that the screws are firmly in place both to ensure that the keyboard is secure and also to eliminate any potential problems with replacing the bezel or battery.
Reattach the bezel (if you removed it) and the laptop battery, making sure that all components have been reattached and are firmly secured.
Once the battery is back in place, press the power button to power up the Gateway laptop and give your operating system a chance to recognize the newly-installed keyboard.
hope this helps
http://www.youtube.com/watch?v=z7fs3nce2g4
watch the video
Oct 06, 2012 | Gateway LT3119u (LUWEW02001) Netbook
How to replace the keys?
You will have to replace the entire keyboard. The problem is with the circuit board that is built into and controls the functioning of the keyboard, not the individual keys. To remove the keyboard, you need to remove the plastic strip with the buttons in it, at the top of the keyboard. This strip usually just snaps into place, but some have two screws on the bottom of the machine that hold it, so if it doesn't want to lift up and snap off easily, then remove any screws directly under the strip. Once you have the strip up and off, you will see the screws that hold the keyboard.
Aug 25, 2008 | Gateway 7330GZ Notebook
I received the replacement keyboard for my Gateway laptop computer without the "easy to read instructions". I was hoping that these instructions for removal of the defective keyboard and...
Hi
The best I could find was the product page for the keyboard. Otherwise you'll need to either contact the people who you bought it off or use a general guide for replacing keyboard such as this one. It does have laptop - specific instructions for some Gateway laptops - hopefully you'll hit lucky!
You could try searching specifically for "(your laptop make & model number) keyboard replacement guide" if the above link does not work. Google usually has the answers! Alternatively if you provide me with the model number I could have a look around for you.
Hope this helps and good luck!
Philip
Jul 13, 2008 | Gateway Computers & Internet
Did you look at the gateway site for the manual? It should be in it. That is what I always do.
May 08, 2008 | Gateway 7405GX Notebook
Connecting Gateway Keyboard to Dell Laptop with PS/2>USB Adaptor
Does the entire keyboard function with the multi-adapter? I am having the same problem, and i just bought a single ps/2 to usb adapter. If it works, let me know. THanks!
Oct 15, 2007 | Gateway 2520915 Keyboard
Computers & Internet Logo
1,470 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
