Question about Canon CanoScan LiDE 600F Flatbed Scanner
Redish/Pinks color to scans.
When ever i try to scan anything it comes out with a redish/pinkish color to it, even if it is a white piece of paper. I'm not sure how to fix the color balance or what i need to do to fix it. I can scan negatives just fine. The color is correct with negatives, but anything else has the red color to it. Thanks.
  • 4,889 Answers
You need to reset your scanner's color management settings to default..
Which utilty software r u using?Arcsoft Photostudio?If yes go to Edit ->preferences
Set RGB settings to the same level(adjust the slider next to red)
If it doesnt work or u r not using back..
Posted on Nov 06, 2007
Line comes up vertically on scanned paper on colored paper only.
have you tried to uninstall the last upgrade? Sometimes they're not working as expected
May 29, 2015 | Office Equipment & Supplies
Color is redish
You have a clogged color print head and needs cleaning or replacement if the old ink hasn't hardened in the jets of the print head.Your printer needs service.
Apr 20, 2010 | Canon Pixma MP950 All-In-One InkJet...
The whites are not as white and there is starting to have a slight pinkish purpleish haze around the edges around the screen its not bad yet but I have tow and you can see that it is not as bright as the...
When an LCD starts getting pinkish to redish hues, the screen is starting to fail. You are in the biggining stages of losing the screen. There is no repair....only replacement.
Jan 16, 2010 | Apple Cinema Display 23" HD Monitor
After TV turned on for 2-3 hours the colors begin to change
The light engine is going bad. To be specific the color wheel is wearing out and cannot be replaced seperately as it's part of the light engine. Mitsubishi extended the warranty on the light engine for an additional two years. You need to contact a local Mit's authorized service center to see if yours is still covered. Better hope so as the light engine is expensive.
Jul 09, 2009 | Mitsubishi WD73727 73" HDTV
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Color is faded on one side when scanned
Apparently you might need to because scanners are most times not reserviceablw when problems of faded output and discolouration is evident.
Properly clean the surface of the scanner and leave your scanning image application to default settings
May 28, 2009 | Office Equipment & Supplies
How to fix / clear unwanted color bands during scan
Try place a couple of pieces of white paper behind what you are scanning. Worked for me
Apr 25, 2009 | Microtek ScanMaker 5950 Flatbed Scanner
is it all redish pink or just a spot?
Mar 18, 2008 | Televison & Video
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
272 people viewed this question
old marine
old marine
