Question about Refrigerators
Whirlpool conquest model side-by-side
MOD # GD25DIXHS00
Serial # SK2137551
Freezer stoppoed freezing, and frig. side is not cooling. I amitain the condessor from dust consistently. Fan is fully operatinal. Power source is in good working condition.
In the past 9 months, a clisking noise woul come on as though something was switching on and ten off. However, it never stopped. In last week, suddenly, everything stopped cooling and freezing. I cleaned the condeser, and then turned on overnight for proper operation. This afternoon the same problem re-ooccurred. Please advise. Many thanks.
  • 3 more comments
  • haberry Nov 05, 2007
    I have tried to find the solution you proposed. I can not find it . Please advise. Thx.
  • Anonymous Jan 11, 2008
    The light is on but the freezer and frig. are not cooling. Something is running but everything in the freezer has thawed and the fridge won't get cooler than 50 f.
  • juki Jan 30, 2008
    Same problem but i did smell a electrical burning smell before it totally stopped cooling/freezing. now hear a clicking
  • galeb May 29, 2008
    Our Whirlpool GD25DIXHS00 refrigerator (purchased July 2000) has the same problem. Two days ago the freezer stopped cooling and the refrigerator side is above 50 now. The fan is working and we cleaned the coils etc. Is 8 years the lifespan of a Whirlpool?
  • toddms68 Jul 21, 2008
    Compressor does not run but fan does. Cycling power off and on I cannot hear tho motor trying to start (humming) or any relays clicking, etc. It's as if the compressor motor is not getting the "on" signal from the temp switch, but the fan does.
You need to replace the compressor start relay/overload. It's on the left side of the compressor. You should be able to remove it from the compressor by hand but you may have to use a flat head screwdriver to pop it loose. When you get it off you can shake it and if it rattles inside it's definitely bad. I bought one for my fridge online for $48. Hope this helps.
Posted on Sep 10, 2010
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
We have a whirlpool GS6SHA conquest side by side and the middle bar between the frig and freezer is hot to the touch. what is wrong?
Either the fan which cools the compressor ( behind the bottom panel behind the refrig ) has stopped ( possibly something caught in the blade or bad fan motor ) , or the coils in front at the bottom behind the kick plate , need cleaning badly .
Aug 04, 2010 | Whirlpool Refrigerators
Mod#RS25AGXN002 FRIG NOT COOLING FREEZER NOT FREEZING
the return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Oct 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Jul 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest side by side (stainless steel front)bought in 2004. Freezer stopped freezing, fridge cooling fine, freezer is running. Thank You!
sounds as if you have an ice buildup restricting the fan from moving airflow to the freezer. Inside the freezer take apart the lower shelf and see if this area is full of ice, if so clean it and defrost it.
Jun 12, 2008 | Whirlpool Refrigerators
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Refrigerators Logo
268 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
