Samsung ML 1710 Laser Printer
Frequent paper jams.
shared by 2 users
posted by ronniegj on Nov 04, 2007
Very frequent paper jam. Paper will not make the first turn in the paper track. Paper is not damaged, just won't make the turn. I usually am able to get it going by turning the paper around to present the opposite end and fluffing the stack of paper, then when it finishes warming up it will go through, but frequently the next page starts the process again.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jan 03, 2008
Printer worked fine for quite awhile then all of a sudden I get error message telling me a paper jam but there is none. It just won't feed the paper through.
Best Solution
posted on Nov 04, 2007
Helpful (85)
eagle338
Rank:Wiz Wiz
Rating: 82%, 1087 votes
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Frequent paper jams.:
I don't want to Accept this solution
Can you Help with these Printers problems?
We have had this printer [Samsung ML 1710] for about 4...
my samsung ml 1710 printer will not fully eject the first...
I changed the toner cartridge because I thought it was low...
I own a Samsung LCD tv/Monitor, I love the picture...
my printer is constantly sounding like it is on...plus the...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
