Freezers Logo
A
Anonymous Posted on May 21, 2014
My ice maker makes too much ice, full indicator not woring
1helpful
Igloo model ICE108. Why does the ice full light stay on when there is no ice in the basket?
Because the ice level sensor is stuck in the full or up position. As long as it is there, the ice maker is shut off and will make no ice.
Oct 27, 2015 • Freezers
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
Ice full when no ice portable ice maker
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
The ice maker does not stop making ice when the bin is full
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperature controller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
hope answer the question
thank you
please vote!
When the room is full stop making ice , the problem is leaking water with rush from the ice maker
Good day,
don't understand your question at all. When room is full. Full of what ??
But for know, I'll include a step by step procedure for repairing ice makers. Any further questions, please just ask..
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Mar 31, 2010 • Freezers
Doesn't make ice cubes. Water doesn't come in.
Hello it sounds like the timer on the ice maker may be the cause. If you open the freezer when the fan is off raise and lower the arm on the ice full shut off. listen for a faint clicking noise you wont hear if fan is going. If it does not click the problem is going to be in the actual switch. I have repaired several with this same problem with the switch but you would probably rather invest in a new ice maker or either buy some trays. As the ice makers can cost up to 200 dollars in some models. The only other thing to check is if the water line is bent or crimped off.
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Top Windchaser Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Windchaser Freezer Expert? Answer questions, earn points and help others
