Question about Gateway FPD1530 15" TFT LCD Flat Panel Monitor
Monitor message i cannot remove "processing auto config message from screen display"
  • vzrep33 Nov 08, 2007
    thanks for ur suggestion, however the monitor and cpu were not purchased seperately.. i bought the entire system from gateway,, they are def compatible.. this just started happening out of the blue.. any other ideas pleeeeeeease? ty
    Novelist:
    Scholar:
  • 96 Answers
The monitor is stuck processing the auto adjustment. This is a problem with the minotr itself only and has nothing to do with your computer having a problem.
Unplug the monitor from everything and then turn it off, let it sit for a few minutes, then turn it on again. There will be a menu button on your monitor, press it and use the arrow keys and the "enter" key (looking like a bent arrow) to find image reset, or it may just say "reset" that will reset the monitor to default. If that doesn't get rid of the message and allow you to begin using your monitor normally again, then your monitor will need to be repaired due to either a faulty button relay, or the circuit card those buttons connect to in your monitor.
Hope this helps.
I just spent an hour with someone else with a very similar problem and found this out.
Posted on Jul 12, 2008
  • 170 Answers
Hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Posted on Nov 05, 2007
When my computer starts it shows message" Auto config please waite" how can I stop this message as it slows down start of computer.
The message you are describing comes from your monitor. The auto config is the screen automatically resizing to match your computers resolution. You will have to consult the instruction manual for your monitor to see if this feature can be disabled.
Mar 08, 2011 | iiyama AS4611UT 18 in. Flat Panel LCD...
Pl. solve my problem "PROCESSING AUTO IMAGE ADJUSTMENT" message display continusly
I've tried all ideas by removing this ,,processing auto image adjustment'", but all of them was not working. So, i found truly and simple solution: The problem is made of constant autoself incorrect working button ,,Auto/set". This button is near ,Turn off/on monitor". Eventually you need to turn off this button, but there is no solution to do it, but i found one - i used hair clipper to press this button PERMANENTLY. And it WORKED, and also no screen buttons are working
Oct 02, 2010 | LG Flatron L1515S 15" LCD Monitor
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
Auto Config Please Wait message
Each monitor has a menu option. Find out with your manual how to access your menu options for your specific model and in there is an option to display messages or warnings. You can turn it off there.
Dec 01, 2008 | Acer Computers & Internet
Processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
Norcent Monitor problem
yea just let it work i mean when it says auto config it means its adjusting monitor settings accordingly to your hardware nd display so just stay back and wait until it does
Sep 02, 2008 | Norcent Technologies Computers & Internet
Display moves when in games
This is because your game is changing your video mode and timing. Check in the game's settings, see if there is a "use default video mode" option or if you can specify the 1440X900 mode manually.
Jul 10, 2008 | Acer X193W LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway FPD1530 15" TFT LCD Flat Panel Monitor Logo
413 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
