Question about Philips Magnavox 27MS343S 27" TV
Magnavox model TS2768C101
Tv was working fine, unpluged cable from back with tv left on and then unpluged tv. When I went to turn tv back on it clicks on and back off. It seems to cycle approx. every ten seconds if you hold the putton in to power on and power off. It also tries to power up on any of the keys ( menu, volume, channel keys)
I have unpluged tv and waited and tried to power it up with no luck.
  • 1,694 Answers
Re: Magnavox model TS2768C101
Requires troubleshoot,locate and replace bad caps in horiz
drive circuit. Usually 47mf/25v..................+ solder any/all
bad connects = prevent maintenance................T.
Posted on Nov 25, 2007
0 characters
3 Points
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Tv will not turn on
A: Is there a humming sound coming from the TV set?
Check the brightness/contrast. If nothing still, remove power to the set for 24 hrs. and reconnect and retry. If it's not coming back up, the PCB ("motherboard") for the set has most likely died. Check for warranty information in your user's manual for further instructions.
B: Is the TV sharing an electrical line with a wall switch?
Remove the set from that circuit and try another outlet. If not, follow the Steps for "A".
C: Was it during a power storm, when it went blank?
Check the outlet with another appliance - if that device works, try the Steps in "A".
Nov 28, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Will not Turn On
It is a problem on the main board and could be the regulator IC or Horizontal output transistor.
Regulater IC should be a STR53041
The HOT is marked on the front
Be sure to check the 100mfd @50v cap next to reg IC
and the transistor on the left N4923
Jul 17, 2008 | Philips Magnavox 27MS343S 27" TV
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Standard (CRT) Televisions
Do you have a cable box? if so unplug and plug back in the box. I do have issues with boxes doing that, try unplugging the tv also. what have you done to try to fix it?
Jul 08, 2007 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox 27MS343S 27" TV Logo
116 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
