Question about Fujitsu AMILO D-8820 Notebook
Faulty power connector to Amilo 1650
The connector for the power pack is faulty and I find it difficult to get the Laptop to charge
  • mr femicapo Apr 22, 2008
    faulty power connector, pci modem installer and mass storage installer problems
  • 4 Answers
You must renew your connector
Posted on Feb 20, 2008
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
The battery saying dischargeing why when the laptop plug in it say charging then about five mins later it say dischargeing why
The power adapter lead/plug that connects into the laptop's power socket maybe be faulty or the laptop's power socket could be faulty.
Connect the power adapter to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 25, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Can i upgrade my video card in the amilo li 1705 laptop and also the battery life time is very very short
Yes you can buy it to nearest computer shop and bring your laptop, I believe they will recommend you the best they have that fit your amilo li laptop! You must replace the battery pack with NEW one, I once try to change the cell, but it absolutely no good. When you charge the battery, charge it when your Laptop turn-off. Better charging time is not more than 4Hours. And if you intend to use your laptop more than the battery life, or when you want to use your laptop with AC power, please remove the battery pack. Always charge the battery pack when your laptop turn-off! GoodLuck!
Jun 13, 2009 | Computers & Internet
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
May 22, 2009 | Dell Inspiron E1505 Notebook
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Computer will not turn on
You need to check the power cord, borrow, beg or steal one to test. If the laptop does not charge with a different power cord then the problem is elsewhere eg. a faulty power pack or even a faulty connector that plugs into the laptop (borrow a multi-meter to check the voltage of your power pack), also borrow a power pack to test your laptop, before you buy or send it away for a quote/repair.
If you determine that the laptop is faulty, then the cost of replacing a motherboard would not be worth it, even if you found one, it would most likely be a second hand one and how would you know it works, also if you are not technically minded you will it difficult to swap motherboards and it may not work when you put it together.
I suggest you put your money towards a new laptop, it will be faster and better.
Nov 15, 2008 | HP Compaq Presario R4000 Notebook
Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Oct 06, 2008 | Computers & Internet
Please whe you change the battery and it does not solve the problem try replacing the "brick" probably the "brick" is not doing its job properly.
Dec 03, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu AMILO Pro V2035 PC Notebook
If it's only 10 months old it is still within the manufacturers warranty, so do not touch or alter anything to do with the charger or battery, as even though the battery is seeming to be the fault, it is normally the motherboard charging point that is faulty or the motherboard not recognising the battery is connected.
May 02, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu AMILO D-8820 Notebook Logo
189 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
