Question about Hitachi 42HDS69 42 in. Plasma Television
Unit will not turn on from standby
Main power switch is on and the RED LED is lit meaning it's in standby but when i go to turn the tv on the RED LED will turn off then come back on and the tv is not on. Normally when i turn the tv on the RED LED will turn off and a BLUE LED will turn on. I tried unplugging the tv for acouple of minutes and then plugging it back in but no luck. Any help is welcome.
  • tvdead Aug 01, 2008
    I have this same issue where you try to turn on the TV but it never leaves the stand by mode. The tv clicks and clicks and then goes back to the stand by mode.
    Before I had a problem with the digital board but the tv actually went to the blue light wich means it tried to power up. when I had this issue i sa red yellow led lights flashing. Took it in and had the pro's take care of it. Can anyone help with the my original issue where the red light stays on and you hear clicking noises as if the tv isn't getting enough power?
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Posted on Jul 24, 2008
Samsung 75 smart tv , is power on or off when red light is on ????
Red light means that the unit is in standby mode, It has power but is not turned on.
Jul 24, 2015 | Samsung New 75"" Class 74.54"" Diag. LED...
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
Panasonic TH 42PA25. Front power switch LED is solid red. SC Board LED (D6583) is not lit. SS Board LED (D6765) is not lit. However, SS Board LED D6769 is lit. I suspect PA or P board.
The TV is on standby mode due to protection; some error in the board. If you have spare boards, try replacing it one by one, starting from display board.
Jul 28, 2012 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
LG L2LC55 HDTV
If you do not get any light on the front panel, it means the 5vdc standby power supply is not working or failed main logic board, you will have to do the power supply inspection first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | LG 42LG50 42 in. LCD HDTV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Orange Led syndrom
I found the following solution on internet:
VIEWPIA LCD
Make: Viewpia
Model: LC-32IEB2
Fault: Unit held down with only orange LED lit
Remedy: Remove the main metal screen cover from main board and check the input
voltage on to the main 3.3Volt regulator IC202 it should be bang on more or less
5Volts, if not replace capacitors C905 330uf 10v C908 470uf 10v both are to be
found in the main power supply section.
J Williams
www.jvsvisual.com
Unfortunately I'm not very technical so now I will need to find someone to do this for me...
Dec 22, 2008 | Televison & Video
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
526 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
