Question about Samsung DVD-V4600 DVD Player/VCR
My dvd player on my samsung home theater system wont read dvds
SOURCE:
SOURCE: DVD player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
  • 31 Answers
SOURCE: doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Posted on Mar 06, 2008
skotkolr
  • 558 Answers
SOURCE: HOME THEATER SYSTEM SET UP
75 ohm coax cable generally does not carry 5.1 surround, you may need to see if your cable box has a 5.1 surround capability, the cable company will be able to help you on that .one other thing the receiver you are using (distribution) may need to have the source changed to the one from the cable box ie. fiber optic or coaxial (orange rca plug). red and white from the cable box does not carry 5.1 surround, only stereo. thanks for using fixya!
Posted on May 28, 2008
ungatt0
  • 32 Answers
SOURCE: dvd does not load
some times its because of the CD (it cannot read the CD) all you have to do is try a different range of CD's to see what the prob is if it still doesnt read it may be coz of a scratched CD / Lens!!!!
Posted on Jun 26, 2008
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
My harman kardon player will read blurays, however it wont read dvds. Any idea why?
More than likely the lens that read dvd discs has failed. On blu-ray players, there are two (2) optical lens. One reads blu-rays and the other dvd/cds. They are independent of one another.
Nov 26, 2014 | JBL Harman Kardon Bds 2 2.1 Blu-ray Home...
Samsung home cinema ht-330 dvds wont play no disc displayed
The most common reason is either a dirty or bad Optical Pickup unit in the player which is what reads the disc, and you will get no disc, cannot read disc etc.
Dec 20, 2012 | Samsung Audio Players & Recorders
Dvd player will not read dvds
1 The problem is the dvds disc which you are using are not compatible with your system. Check the the regional code at the back of your dvd cover and check if your dvd player can play those dvds. This information is given in the booklet provided with your system.
Jan 04, 2010 | Panasonic sa-ht800V Home Theater Audio...
SAMSUNG HT-P10 DIGITAL HOME THEATER SYSTEM wont play DVDs
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Dvd+r dl
depends on what format the dvd burner burnt it, mpeg wav avi etc...i had the same problem. basically the older dvd players wont reconize these formats thats why.
Mar 13, 2009 | Panasonic Home Theater System System
DVD not play dvds and making noises
Probably is dirthy laser...
Try to clean it,and,if that doesn't work,you must change it!
Feb 09, 2009 | Samsung Audio Players & Recorders
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
Cant use dvd player, the word lock keeps coming up, dont know how to remove it, the model is a samsung digital home theater system HT-DM150
i have a samsung dvd theater system ht dm150 it will sometimes read the dvds dut majority of the time it wont read any dvd i even used a cd cleaner on it. 80% of the time it will play music cds.
Apr 21, 2008 | Televison & Video
Disc reading
hi there
long reading time for cds or dvds only means that there might be dust or residues hindering your cd lens to accurately read the data of the cd/dvd. what you can do is try to clean the lens with a cd cleaner.always check the cd/dvd that you insert are clean and fre of dust . if this still wont work and the player still have the long time to read the cd/dvds, my advise is to bring this to a service center and have this checked out.
hope this helps.
Feb 05, 2008 | Samsung HTQ45 System
Samsung ht-db650
I dont think its connected. anyway, make sure DVD is clean and unscratched. If it wont help and these are commercial DVDs, then there is probably something wrong with them. If they are home made DVDs, then it may be that your player doesn't handle them well and you can try to burn it a other dvd format... look in you r manual to find out which format are compatible.. Good luck.
Jan 15, 2006 | Samsung HTDB650 System
Samsung DVD-V4600 DVD Player/VCR Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
