I was mowing my lawn when white smoke started coming out of the side. I pushed it to the sidewalk to look at it, and as I was pushing it, I noticed oil leaking onto the base of the mower. It was coming from the area where the air filter is. I opened that part up, and the air filter and all the area around it is covered in oil.
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
