Question about E-Machines eMachines W2686 PC Desktop
My computer w2686 do not start
I have a Emachines W2686, I buyed I memory of 512mb with a bus of 333mhz. After I plugged the new memory the computer do not start. The hard drive do not start, also can not open my dvd drive and the light of the sd cards stills on. If unplug the hard drive from the motherboard I can heard it working. Also the same happens with the dvd drive if I unplugged I can opened normally. What can I do?
Thanks in advance.
  • 143 Answers
I'm assuming that when you say "unplugged" that are you are meaning to say that you're unplugging the IDE ribbon but still leaving the power plugged in to the device.
Try resetting your CMOS settings by using the jumper on the motherboard. (Usually labeled as "JP1" or "CMOS" on the board.) You have to short the pins with the jumper for no less than 3 seconds to clear the CMOS settings back to factory default. Try booting the system after that.
If that doesn't work, try taking out all of the old memory and leaving in the new memory. See if that works. (Sometimes different memory sticks do not like one another and will fight for control of the system's memory controller.)
If that fails, try taking the new memory out and put the old memory in. See if it boots that way. If it does boot with the old memory, there is most likely an incompatability with the new memory and the motherboard.
Just because it's an Athlon XP 2600+ does not mean that it runs at 333 MHz FSB. There are two different versions of the 2600+. The 266 MHz and the 333 MHz.
Check to see if there is any labeling on the old memory. If you find a sticker on the RAM and it says "PC2100" on there then you were previously running 266MHz memory. This means that the motherboard itself is also most likely 266 MHz FSB.
Most OEM manufacturers used the slower boards and memory to cut down on production costs figuring that your average customer wouldn't notice or care.
So if your system boots on the old memory and it is PC2100 memory, then the two likely possibilities are as follows:
1.) The motherboard is not compatible with the brand/make of memory that you bought.
2.) The memory is 333 MHz and the board is 266 MHz and is not able to downclock the memory to run at 266 MHz. (Which most boards are usually able to do.)
If the memory is not compatible with motherboard then you may have to take it back and select a different brand. I would research that information for you if I had the memory information available to me.
Here is a nice little tool from PNY for selecting memory that is compatible for your system. PNY is a very commonly-found brand in most retail stores and should be easy to find.
Select the appropriate information from the configurator tool to find the right memory for your machine.
Good luck.
Posted on Nov 04, 2007
I have an Emachince W2686 and I need a face plate for it. The button got stuck and it pulled the wires completely off the back of it. What do I do to fix this problem?
Pulled the wires off of just the Power On switch?
(Goes inside the Power On button)
Or did you pull ALL the wires off of the Front Panel? (Also known as Front Bezel)
The eMachines W2686 uses a NexGen computer case.
Is this NexGen Front Bezel like yours?
May 14, 2010 | E-Machines eMachines W2686 PC Desktop
My eMachine Model W2686 CPU will not turn on. Is
it's not issue of CPU problem 1st chack your CPU Fan is working or not then only u can find the pro
Apr 13, 2010 | E-Machines eMachines W2686 PC Desktop
How to finde the right ram and fit it iqon desk top it has 1g i want to fit 2g
This link will give you the specs you need and then you can go and purchase the ram wherever you want to. If the page displays weird when you click on the link just refresh the page and all should be well.
Nov 20, 2009 | E-Machines eMachines W2686 PC Desktop
W2686 power supply problem?
Yes, any power supply will do as long as it fits in the case.
Either a regular power supply
a Micro power supply
They can be purchased online from Tigerdirect in any number of wattages.
Jun 14, 2009 | E-Machines eMachines W2686 PC Desktop
Your problem would not be with a battery, but the power supply. Try plugging into a different outlet just to make sure, but sounds like you may need a new power supply.
Jun 11, 2009 | E-Machines eMachines W2686 PC Desktop
W2686 eMachine doesnt turn on after changing powersupplies
hi im josh in cebu phils.may i help you? Friend if the pc does'nt power on even you have replace the power supply. it means that there is a major problem in your hardware definetly if not the power suppy the motherboard or the sure to have compatible mainboard and processor because there are mainboard that does'nt support a certain processor please try to check it .try to replace another motherboard that is compatible to your processor. or check the connection of the power on button and the wires from supply to motherboard.please do that to solve your problem hope i helped you good luck.
Feb 25, 2009 | E-Machines eMachines W2686 PC Desktop
E-machine not accepting new memory
try to check  whether the ram  frquency  matches the specifications....
any way  three beep  means a graphics card problem  so  if you have one remove it and try to reboot
but i think this has to do with the RAM frequency
pls do post back
Nov 26, 2008 | E-Machines eMachines W2686 PC Desktop
My computer do not start
Does it work if you put the old RAM back in?
If so, I'd say the new RAM you got is bad.
Nov 04, 2007 | E-Machines eMachines W2686 PC Desktop
E-Machines eMachines W2686 PC Desktop Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
