Mtd Yard - Man 160cc, 21" Self - Propelled Lawnmower.
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
SOURCE: Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
SOURCE: what type of oil do you use for 6.5 hp yardman
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
