This could happen due to 1. Worn wiper blade 2. Worn Drum 3. Worn PCR above 3 are inside the toner, if you know how to replace them replace or install a new toner, if the problem still persists you have to check the fuser or contact a technician..
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
use plane paper of 60-80 gsm if your printed paper is offset/screen print it will repeat and shadow appears because of high temprature in fussing unit.
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Try uninstalling the HP software that it came with. You can do this either through Start Menu>Control Panel>Add/Remove Programs or go to Start Menu>All Programs>HP and uninstall through there. Then go to HP's website and download the updated software for your printer and reinstall everything. That should get you going.
Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing.
Ragards,
MukeshS
