Question about Sony VAIO VGN-SZ460N/C Notebook
How do you turn on the mouse
Accidently turned off the mouse. mouse arrow does not move. how do you turn the mouse arrow back on?
My desktop image shifts as I move my mouse arrow around the screen. How do I stablize the image
What you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and scroll down on your mouse, this should fix it. Hope this helps.
Nov 18, 2010 | Apple iMac G4 Desktop
The arrow cursor ( pointer) has stopped in one place as though it has frozen itself there and it you use the touch pad nothing happens what do i do next
if it works with a mouse plugged in you might have accidently turned the mouse pad off, use FN key and on mine it's F7 to turn it off and on. hope this works for you
Sep 05, 2010 | Toshiba Satellite A60 Notebook
No toolbar/ deskbar
you probably moved it by accident try moving your mouse cursor near the bottom or sides of the screen, when the cursor almost dissapears, it should change from a single white arrow to a double (up/down) arrow. click left and drag up, normally you bar should reappear.
Feb 23, 2010 | Acer Computers & Internet
The arrow dosnot move (M105-s3041)
Lol. This happened to me about 6 months ago, Toshiba has a program called 'TouchPad' Utillity. Which basically enables you to turn ON/OFF the mouse pad, It's shipped with the operating system, Unfortunately if you do turn it off, The mouse pad won't respond and there is no way you can turn it back on, It took my 12 hours to figure this out,It was frustrating, You will need a mouse, Preferably a USB one, plug this in and go to your icon bar in the bottom right hand corner of your desktop screen and there should be an icon saying 'TOUCHPAD', Right click it, Go up and turn it back on, Then you will be back in business:)
Jan 04, 2010 | Toshiba Satellite M105-S3041Notebook
Accidently uninstalled softtware for the mouse and now have no mouse to access anything. What are my options and how do I get the mouse backé
Switch on the computer and use the keyboard as they did in the pre-mouse days
ie tab key to move around the screen and arrow navigation buttons
Or go out and buy a really cheap USB mouse plug it in and then go get the drivers from the GE website
Nov 20, 2009 | GE Wireless Optical Mouse
The start menu and task bar appear to be off the screen on my desktop and auto die mode is not on:(
Check to see if AUTO HIDE is not enabled in taskbar settings, move your mouse cursor to the bottom of the screen if enabled the Startmenu and taskbar will re-appear, if not then it was possibly resized accidently, move your cursor to the bottom again if it turns into two arrows pointing up and down then click and hold and drag up and it should be revealed again.
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Arrow wont move
Dear Fayereid01,
You said "I have a dell computer and when I turn it on to the desktop the arrow wont move to go any further its a desktop with a IBM keyboard"
Make sure that the mouse is plugged into the the correct port. If the mouse you are using is a USB mouse then try other USB ports. If it is another type of mouse that uses a different plug, then try all the ports on your computer that it fits into until it works. It sounds unprofessional but it should work.
If none of this works then put in the CD that should of come with you mouse and install the drivers for your mouse. If you cant find the disc for your mouse then go online to the manufacturers website and you should be able to download the drivers there.
If i was helpful please rate me positively
Jul 02, 2009 | Dell desktop and monitor -Inspiron...
Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Mouse wheel scrolling has changed
try control panel settings for your mouse
Apr 03, 2009 | Computers & Internet
Sony VAIO VGN-SZ460N/C Notebook Logo
24 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
