Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Side by Side Ref. water will not shut off in door
Just pulled ref. out of storage, hooked up water, and the water is continuously running, like I've put a glass under it and am pushing on the lever, but I'm not. Help!
  • Anonymous Mar 12, 2014
    Water from door runs aftr glass is removed
    Sergeant:
  • 288 Answers
The lever is activated by a switch that opens the valve when you push it with a glass. The switch and/or the solenoid is the problem. as it was just taken out of storage, look at the switch behind the glass lever. You may be able to un-stick it by hand.
Posted on Dec 26, 2007
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
Water does not come out of door. I can hear the click and the ice is working on the other side so it is getting water.
check your water tank in the ref. looking under the veg. drawers. there it should be on the back of ref. if no water than your solenoird in back of ref. might be bad. there is two one for ice maker one for water.. ok
Feb 11, 2011 | Whirlpool Refrigerators
How do i remove water filter under the side by side refrigerator
filter should be removede by turning filter counter clockwise,as if "unscrewing",so to speak.no need to shut off water or anything,just unscrew-tip:might be easier to remove by removing ref. grill. ref. grill removes easier by doing this w/ both doors open
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whilpool ed25sm Cold water dispenser leaks
your water valve is bad. behind the ref. in back is a cover. unplung unit remove ref. from back wall about 2-4 ft.remove back cover and you will see a water valve. thats the piece that the hose (your incoming water supply line hooks upto) 1/2 fitting. turn water suppy off. remove screw holding valve. disconnect wires one bye one and hoses one bye one.(so you dont mix them up).if your ref has a inline water filter and has not been replaced in a while i woiuld try that first. valve is about 45-85/ depending on your model ,i do not have that.and labor roughly 75-125 to replace depending on were you live and who you use. hope this helps you.
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool ref side by side the water
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 20, 2009 | Refrigerators
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE SideBySide Ref GSS25VGMD WW
if temps are ok, i honestly don't think you have a problem
Jun 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool S/S Ref with Ice in Door - Mod # ED5FHEXMQ
Most fridges run a defrost cycle 2 or 3 times a day. When this is happening a normal pop and sizzle sound will be heard. Otherwise I will need more information. Ice makers need to be cold enough to dispense ice, but not to fill. If yours will not fill, it may be the water filter.
Feb 20, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
