Question about Jwin JD-TV1300 13 in. TV/DVD Combo
No remote i have miss place the supergirl tv/dvd remote and i need to order another one if possible
Re: no remote
I found out that a company named 'Kids Station' makes the tv. Unfortunately, they are not on my universal remote list. If anybody could figure out which codes work, please post them!
Here are two links which have the compant name.
Posted on Jun 09, 2008
0 characters
3 Points
I have a HCT 133S TV/DVD combo, the original remote is missing and need to get to the menu, any idea how to get to the menu without the remote? (no menu button on TV)
Going to need a remote--original if possible as many universals will not program for all sets and if do may not have this feature for your set.
Jun 01, 2012 | Combination Televisions
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.
If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
Apr 05, 2012 | Jwin Combination Televisions
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Combination Televisions
Remote won`t operate tv stuck on channel 99 w/ no signal showing
Some units have a little hole where you can insert a straightened paper clip and manually retract the DVD.
Make sure the power is turned off first.
"Your mileage may vary."
Jun 30, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
No remote
Hello sweettexas,
I you use a universal remote you might be able to use some of your programming features, you can get such a remote from Best Buy, Radio Shack, Target, or Wal-Mart. Now for the down side with the universal remote you will only get some of your programming functions as I said earlier. If you want all of those features you are going to have to contact the manufacture and order a remote for your television. There are places on line such as ebay, or amazon where you can buy a remote for this set, and this might be considered as an option also. In any event whether
you buy a universal remote or buy an OEM remote, you will need a remote to "properly" setup your TV. You can use the front panel controls for limited setup however doing that is tedious.
I hope this helps,
Thank you,
Jan 26, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
Nov 20, 2007 | KLH KDT133UY 13 in. TV/DVD Combo
Supergirl tv doesn't stay on
This is an indication that there might be a cold solder connection in your unit. I would suggest that you have a qualified TV technincian look at your set to see if this is the problem. I don't believe that you have a startup circuit or a IHVT/HOT problem because you are able to get the unit working at times by plugging the set in. This sounds like a case of poor circuit board work. Just in case it is a startup circuit issue, you may have a faulty component in the primary power supply that provide voltage to the startup circuit.
Aug 23, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Jwin JD-TV1300 13 in. TV/DVD Combo Logo
362 people viewed this question
Top Jwin Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Jwin Combination Television Expert? Answer questions, earn points and help others
