Question about Lexmark Z715 InkJet Printer
Printer will not print
Change print to labtop not it will not will come on and act like it is printing. new black cartridge, color-0
  • 148 Answers
Re: printer will not print
Uninstall the printer, reboot your system and reinstall the printer using your software/driver cd that came with the printer.
Posted on Mar 10, 2008
0 characters
3 Points
My printer is printing blank pages
I used to have one of these printers.
1. Check the ink levels.
2. Try printing on DVD.
The C309 has a black photo cartridge.
Text prints from the regular black cartridge and pictures print from the photo black cartridge.
THe best way to tell if by checking first the ink levels and replace cartridge if necessary.
One thing you can do to check if the printer is printing is by adjusting on the Printer Setttings and printing on one color.
To do this you need to choose the color from a circular palette .
Another way is to use Word or any other processor and change the font color to blue and print it.
Hope it helps.
Feb 05, 2011 | HP Photosmart Premium C309A All-In-One...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Won't print in color
All cartridges are shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
Nov 20, 2008 | HP LaserJet 2840 All-In-One Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Printers & Copiers
Clogged print head
Please click on this link:
Even after cleaning you get the same results you need to contact lexmark and get the cartridge changed as the cart comes with 6 months warranty ...good luck...
Jul 16, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Only black!
The printer require print head repalcement.
Apr 18, 2008 | Canon BubbleJet i550 InkJet Printer
Sounds like a driver problem we can prove this by testing printer disconnected to computer, press the blue button 5 time rapidly, printer should do a test print., If this works then there is nothing wrong with printer itself it is a problem with the way your laptop is comunicating with the printer, download and reinstall driver, but before you do delete old driver (control panel / printer and faxs, del brother icon.) then unplug from laptop and download and install connecting when softwate prompts you to connect it.
Download driver HERE
Nov 16, 2007 | Brother HL-2040 Laser Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark Z715 InkJet Printer Logo
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
