When you turn the computer on and the first display appears, quickly press the "Pause/Break" key and read the instructions to enter the BIOS of change Boot Sequence. It is usually press [Delete] key. Press [Enter] key to continue from PAUSE and then press the BIOS key. In the BIOS, go to boot and set your CD/DVD drive as FIRST BOOT. Open the CD/DVD drive and inset your Windows XP disk. Press [F10] to save options and [Enter] to reboot. When the computer reboots, choose to install Windows and follow the prompts. You will come to a menu choice to format the drive, pick "QUICK FORMAT" in either FAT 32 or NTFS. Continue to follow the prompts and you will install Windows XP Home with your validation key.
Really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Use a product key recovery program to find your lost key. An example of such a program is Product Key Explorer
Install the program by double-clicking on the file you just downloaded and going through the installation process.
Open the program when ready and then click "select computer" and make sure it says "Local Computer." Click on the "Find Keys" button.
Locate the program that you installed through your CD-ROM. Next to the product name should be your product key.
From here: http://www.nsauditor.com/product_key_finder.html
Good luck.
