Related Tags:
This problem should be removed because:
Problem with RCA D56W20 56 in. Rear Projection Television
RCA D56W20 no power and whistling
First, thank you for any and all help. I will try to be descriptive
I have an RCA D56W20 tv recent got an electrical burning smell and now when the tv is plugged in I get a power light and a "whistling" sound then shuts down. it will repeat this cycle within a few seconds three times and then nothing. I never actually get any picture. I have read a previous post mentioning the Flyback Transformer and the Transistor-Horizontal. I would like to know if this is the correct assessment and if so. Where could I get pictures of these parts.? to have a better understanding of what needs to be done.
I have not worked on tv's before, but I do work with computer mainboards and have excellent soldering skills. I have taken the rear lower cover off of the unit and can see several boards. I have used great caution not to touch anything at this point as I know it can be very dangerous to actually work on tvs. I have looked up pricing on partstore.com for the two parts. I can here the "whistle" or "small siren" sound coming from what I believe is the rear far left board. Again any help would be great.
Solutions (1)
ok. the FLyback is the large black part on the lower left corner.. has large red wire comeing from it... the HOrizontal.. is the large black transistor right in front on the left side on the largest heat sink..getting these parts are tricky.. you must get some numbers on the part itself..there are three different flybacks.... and the horizontal is ussally 259899 rca part number. Good luck and if you need any more assitance email me at FORDTV.com ; I work on alot these chasis
power on trouble
when i plug in the TV and press power the tv makes a whistle sound and powers off on its own and repeats that same problem 3 times.
where would i find a
where would i find a fly back for d56w20 tv
when i turn on tv u hear a whistle sound and light
when i turn on tv u hear a whistle sound and light comes on then off then whistle sound it does this 3 time and i get nothing
Hello, I have a 52in RCA projection tv, model
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button...
Add Your Solution
my tv goes off stays on about a minute and turns...
tv shows good picture just recently it would shut completly off after being turned on tried too see if sleep timer was...
Protective Screen Cracked
How do I replace or remove the protective screen that is cracked from my television
continuously blows power supply fuse
the tv wont power on replaced fuse with same amp fuse and blows fuse everytime
my rca hdtv monitor 55 inch turns itself off in 5
my rca hdtv monitor 55 inch turns itself off in 5 minutes.
See all RCA D56W20 56 in. Rear Projection Television Problems
Fix-O-Meter
98
98 people viewed this problem
- 0 people are following this problem. Be the first!
Top RCA Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
ok so you r going to replace the board? you have a new one?... buy the looks of your picture you do have the units that can remove these cables from the flyback..this is very hard. the black wire you have to pull straight up and firmly. the red one you you slide the boot up and then there is a tiny gromet tpy clip very difficult to remove i break 75 percent of the ones i remove. was thinking since you have a new board did the new board come with the cables? you come better going to the front of tv and pulling the other end off. Sorry my email has changed WIllie@fordtv.com
