Question about RCA 32F531T 32" TV
Can't get into service mode.
I've tried all the ways to get into service mode on this TV and can't get there. Am having a problem with the horizontal width. Have tried holding the menu button and then power, vol +. Have tried holding the chan - and vol - and it will not go into service mode. Do you have any other way to get into it on this TV.
  • 375 Answers
Invest in a service call,you tried .
Posted on Mar 27, 2008
How do I unlock the setup options for horizontal & vertical adjustments on my 55" HDT 51M 2006 Plasma TV won't let me access the horizontal or vertical options in setup in RGB 1 mode.
You have to enter the service mode option to it, to do horizontal and vertical adjustments. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 25, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
Horizontal adjustment
What is the brand name and model number to your TV? Provide more details please. Actually what do you want to adjust? If it is horizontal width, you have to enter its service mode to select this option. If you wish to get more details about how to enter service mode to different models of remote controls, check this link.
Feb 26, 2013 | Televison & Video
My tv has a sound and no picture
Its horizontal output section circuit should be troubleshooted. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 23, 2013 | Philips Magnavox 27MS343S 27" TV
I just bought a used Loewe TV model number ACO938PB. I can;t get the picture to fill the screen. I've changed the settings inside the TV and the 6X9 format works best, but there are still bars of black...
I had a similar problem, and I fixed it with my new Sony flat screen by going into the zoom mode and then menu on the tv remote. You can then access settings such as horizontal and vertical and change them so that your screen can adjust. The only way you can access those settings is in zoom mode.
May 24, 2011 | Loewe Televison & Video
Just got this tv from friend. has no remote. screen is black. sound is good. when you push menu button, white line goes across horizontally the screen.
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
Jan 05, 2011 | RCA F25442 25" TV
Picture is too to fix it?
may be due to high B+ vlatage if it's 21' Tv B+ve vlatage around 115V if its normal try to go to service mode prassing OK butten in TV and menu batten in remote before that minimize the volume to 0
then check the horizontal size and try to low value .
if not help change capacitor between ground and horizontal york winding may be 0.047 uf 2KV
Aug 26, 2010 | Televison & Video
Need a service code for TCL TV model DP29E10C
Hi, tcl dp29e10c model
The TV's horizontal display is messed up and I need the service mode code to be able to do this
Aug 20, 2009 | Tvone TV-207 Television
Overscan is off a bit
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Jul 09, 2007 | Philips Magnavox 27MS343S 27" TV
RCA 32F531T 32" TV Logo
193 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
