Question about Sony SA-WX700 Subwoofer
No sound from speaker
After I unplugged the sppeaker from the wall socket and plugged it back in after I moved it to another location, the speaker no longer produced sound. I opened it up and it looks like a resister is burned out. I need to find the value of it so I can get another one and replace it. Any idea where I can get the value of it. It is resister number R830. Thank you!
  • 13 more comments
  • Anonymous Nov 22, 2007
    Tried connecting from receiver using regular speaker wire...get no sound at all. Is there a fuse or anyting of that nature in this product?
  • Anonymous Dec 15, 2007
    When you turn on speaker the power indicator light comes on green and stays on for about 5 seconds and the goes back offf. you can hear the power on relay click on then off.
  • Anonymous Dec 21, 2007
    I have the same problem with the same parts burned, what is the cause and what can i do to repair this.
  • martini2055p Dec 21, 2007
    I am experiencing the same problem with this subwoofer and found the same resistors burned, what can i do?
  • Rbnot Dec 28, 2007
    Same problem; power is on (green LED) but no sound. Confirmed that it's not the interconnecting cable but that's as far as I've gotten.
  • quique69 Jan 02, 2008
    I have simillar symptoms. One day the fairly new wolfer stopped working. I have power to it, but no sound. Most of the postings mention a bad resistor. How do I determine if this is my rootcause, and where do I go about getting a new one if that is the case?
  • sloney Jan 07, 2008
    Same problem. One day it worked, next day it didn't. Tried different wires to the receiver. Power light is on, no sound.
  • METTLEHED2 Apr 08, 2008
    I have R830 burned as well as capacitor C860 next to it is dead.
    anyone have a schematic with these values? Mine are both so burned I can't read them.
  • Cyno May 27, 2008
    Same thing, unplugged, moved to another room and sat for a week while flooring work was done, moved back, dead. Nothing seems burned, anyone find a schematic? If someone is looking for a resistor value still, I can probably still read mine.
  • mopar1 Jul 03, 2008
    sony sa-wx700 power but no sound. fuse or resistor? have done nothing yet
  • schumbler Aug 07, 2008
    I have the same problem with my sub, it just quit working one day. I dissassembled it and it appears that the board is burned near one of the fuses. My brother bought the same sub after I got mine and his did the same exact thing 3 days after mine died.
    Sony has some quality issues, every Sony product I have ever owned has had problems, Camcorder, Trinitron TV, Car Audio unit and Rack Style Home Theatre system. I dont think I will by anymore sony products.
    If anyone can reccomend a fix for this that would be appreciated.
  • Anonymous Nov 10, 2008
    7no sound
  • Christopher Rafter Dec 23, 2008
    Had the same problem. Sub would turn on, heard it click, no sound. Opened it up. Lots of screws. Don't be scared, just keep em in a cup. Detach the ribbon cables to get at the main board. I found that C860 was scorched. Replaced it with a 0.1 uf ceramic cap from Radio Shack (the actual value of the bad component was 0.082 uf). Had to de-solder the old one and solder in the new one, but it works again. Thanks!
  • elteez Dec 25, 2008
    Blueliar, It's been broken for awile. Saw this post thought i would check it out. Sure enough the # C860 is Burned up. Now I guess I'll have an Extra Sub lol..Thanks
  • tlnphoto Jan 15, 2009
    I have the same problem. This is the second subwoofer, same model that has done this. They seem to last 2-3 years. I took the cover off the circuit boards and didn't see anything burned. I guess I need to look at the bottom of the boards. Any solutions out there, other than not to buy Sony.
Direct from Sony:
c860 is Part # 113616400 $2.14
r830 is Part # 121284900 $2.14
Posted on Dec 29, 2008
Replace R830 and 831. They are 4.7 ohm 5% 1/4w fusible.
Check thermisitors THP 801 & 802.
c860 is listed as 082 mf 5% 50v. This was changed but I dont have the new part number.
Posted on Apr 28, 2008
Posted on Nov 29, 2007
Speakers won't power on when plugged in
firstly check your power cable by moving the wire in various directions while it is plugged in ac outlet and powered on, if it lit up the standby power LED then the prob lies on the power cable. If not, try opening the speaker system box itself (be sure to unplugged the power cable before opening the box), then visually check inside for the little cylindrical glass type tube(if the circuitry still uses this kind of fuse) if it is burnt-out.
Hope this help pal...
Feb 23, 2013 | Labtec Pulse 285 Computer Speakers
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
Everything is plugged in turned on but no sound. I recently moved my computer system to a new location and have not been able to get the speakers to work help
I assume this is a powered unit, so first off make sure the power cord is plugged into the wall and the speakers. then make sure you are plugged into the correct jack on the PC. It is usually green in color. Finally, make sure the volume on both the speakers and the PC are turned up. Report back wit hresults.
Jul 01, 2011 | Harman Kardon Audio Players & Recorders
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
Beautiful picture,no sound
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Oct 23, 2010 | RCA 27V514T 27" TV
Speakers have no sound coming from them.
There is not fuse for the speakers themselves. The speakers maybe blown out. I would take a speaker out and connect it to the home stereo and see if it works. I would check to see if the speakers are plugged in also.
May 01, 2010 | 2000 Volkswagen Jetta TDI
Computer powers up but no video even tried with another graphics card
Feb 26, 2010 | EliteGroup K7VMA Motherboard
Since moving house can't get sound from PC speakers, packed, unpacked, disconnected and reconnected myself, I must have missed out a connection or connected something wrongly. Regards Stan
I suppose that you have plugged the green plug of the speakers in the green socket from the mainboard, in the back. And , of course, the speakers are still functional - try them with any other device that has a 3.5 mm plug.
Probably the audio setup was disturbed: unplug the speakers from the pc, reboot, plug in the speakers - the Audio Manager (the one that controls what and where is plugged) should open to ask you what has been plugged. If it doesn't do that unplug the speakers again and open it manually. If when you plug the speakers it doesn't sense that then the audio driver is busted - reinstall it.
Nov 09, 2009 | Acer Aspireā„¢ T180 PC Desktop
Whre do i plug extra speakers at? when i plug in front it cancels the other sppeakers
they go to the green terminal, and yes it will cancel out any built in speaker, no way around that.
Sep 18, 2009 | Audio Players & Recorders
Sony SA-WX700 Subwoofer Logo
751 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
