SOURCE: 2004 Mercury Monterey 70k CEL code PO401
po401 egr flow insufficient vaulve could be stuck or disconected
SOURCE: 2005 Mercury Monterey with check engine code
P0128 is Coolant Thermostat ( Coolant Temp Below Thermostat Regulating Temperature ). The thermostat may be stuck open, preventing normal operating Temperature from beeing reached.How is the heat inside the car is it below normal ? Or the engine Coolant Temperature Sensor may be faulty and needs to be replaced. Good Luck and have a good XMASS.
SOURCE: cruise control on 2005 mercury
IF ANYONE IS WILLING TO ASSIST WITH A FREE ANSWER FOR 04-05 MERC. MONTEREY MINIVAN CRUISE CONTROLL STOPPED WORKING , ( fuse is ok) IT WOULD BE SO APPRECIATED. MY EMAIL IS. [email protected].
SOURCE: how do you replace the light bulb in the clock
It's not as bad as it sounds if it like my 2004. The clock is accessed under the dask glove box/flipper compartment. You access it by lifting out the rubber tray/mat. That will expose a bolt/nut that holds the plastic shell in place. Take off the nut then gently pry out the tray, starting in the front and working along each side towards the back. The clock back is just underneath this. The bulb looks like a small hex bolt and is removed with a 6 mm socket (you don't need to remove the white plastic backing). Once you've done this, just put everything back in revers order. It took me 20 minutes all together. The hardest part was paying $13.75 for the tiniest lightbulb I've ever purchased. :-) This is a link that someone else posted which shows some pictures of what it all looks like. It's well worth the effort, especially since my wife is much happier now (and it's $47 cheaper than what the Mercury dealer quoted me to replace it). Good luck!
