Question about Kodak EasyShare Z730 Digital Camera
Joystick The joystick on my camera does not work when pushed straight down. works ok up and down and side to side. Thanks for your help.
  • JoAnder Mar 11, 2008
    I have the same problem of no response when I push down on the cheap joystick control for this camera. I've used this very little and even though the camera is past its one year warranty, I think it should still be working!! I'd love to have an answer to this. I've recharged the battery but there isn't much else to do, other than throw the camera against a wall! Just kidding.
  • mandreasen Oct 08, 2008
    Our joystick also does not function when pressing it in. It works up, down, and left. It doesn't seem to work to the right.
While trying to fix this problem today I discovered something that seems to help, at least in my case. If I push down on the small button located below the joystick/onoff button, while also tapping the OK button, the camera responds to the OK. (This is the display/info button.) I'm not sure why this works or whether it would help in every case, but it would be worth a try. I've been able to finally set my date and make other changes necessary after recharging my battery.
Posted on Mar 11, 2008
How can I use it as a camera? I have it all plugged in and installed but it won't regester as a webcam :/
Connect camera to PC with USB cable. On camera switch on and press joystick/OK to get menue on screen. Move joystick to get the set-up icon highlighted and press in OK. Use joystick down arrow to move down menue to "USB mode". Use joystick right or left arrow to change setting to PC CAM. Press OK and you should now have camera acting as a webcam.
Mar 16, 2011 | Fuji FinePix F601 Zoom Digital Camera
Speed lights flash alltogether at the same time chair will not run
The chair is in sleep mode or lockout mode. To unlock-- turn on the chair, immediately push the joystick straight forward until you hear a beep then push it straight back until you hear another beep then release to center. This should unlock the joystick. Turn the chair off then back on and you should get normal operation Hope this helps
Jan 27, 2011 | Pride Jazzy 1113 Power Chair
My touch screen on the right side no longer is working so that I can not enter any data. any suggestions
you may have to replace the touch screen itself. it should be available at
Nov 05, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
Joystick won't work. I have to push straight down and then over to get any action, and then only sometimes does it work. It seems to have loosened.
Cameras have moving parts and therefore open spaces for dirt to get in and "gunk" things up- that's why they make camera cases- even storing your camera in a Zip Lock sandwich bag, is way better than the bottom of a purse.
Jul 07, 2009 | Kodak EasyShare Z760 Digital Camera
Left side and upe side joystick not working
yeah it happen with sony ericsson phone joystick problem.u have joystick problem u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.thanks
Apr 27, 2009 | Sony Ericsson K510i Cellular Phone
Dx7630 kodak easyshare
the 5-way switch breaks it's solder connections on several Kodak models. if you have a soldering iron with a fine tip and are comfortable working on small soldering joints it is possible to repair the joystick (there are 10 solder connections on a 1/4 inch square switch, 3 on two sides and 2 on the other two sides)
Sep 29, 2008 | Kodak EasyShare DX7630 Digital Camera
My joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Jul 10, 2008 | Kodak EasyShare Z760 Digital Camera
Switch it on auto (or easy) first and see if focus works that way. If your on manual (or P) You have to use the joystick on the display to control the focus. All you do is push the center button on the joystick, move the joystick down to focus, press the center on the joystick and adjust it left or right. Press the center on the joystick when corrected.
Jun 22, 2008 | Canon MV730i Mini DV Digital Camcorder
Kodak easy share self-timer
You use the the self timer as follows:
(1) Push the Menu button on back of camera
(2) Scroll through the Menu items using the small joystick located in the center of your circular selector switch, until you highlight the self timer ON/OFF area
(3) Push the small joystick straight in, like a button
(4) Use the joystick to highlight the on position
(5) Push the joystick button
(6) & just snap the picture as usual.
You will have to use the viewfinder instead of the screen to point the camera.
Hope this helps
Dec 25, 2007 | Kodak EasyShare DX7440 Digital Camera
Joystick porblem
when u getting that problem just switched off and restart it work autometically...or else open the front cover and clean it.
Jul 30, 2007 | Nokia 6600
Kodak EasyShare Z730 Digital Camera Logo
240 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
