Question about Sony SLV-N750 VHS/S-VHS playback VCR
  • Anonymous Dec 23, 2007
    Have the same problem. Tape seems to be stuck in VCR. Will not play or eject. When I hit eject, VCR shuts off. I have tried unplugging VCR for a while and trying again. Has had no effect.
    Problem Solver:
  • 5 Answers
Hi dear look like loding gayr broken if it is then u can't do much about it even theu u figure out the gaier brokin .ok cheack the gair under the mechnisem or right hand site all vcr gair have timing set up with a mod swtich every gair have mark on it or holin it .they have to match ....if dont find any brokin gaier so find the mode switch trry to clean that some time they get old & contcat not good any mor function error (make sure the timing of gayer very important mark evry step u do so u can put back to gather )good luk
Posted on Dec 27, 2007
When pressing the eject button the front door doesn't open (it ejects the tape, but have to manually lift up the door to let the tape out). How can I fix this problem?
It's probably a small spring that has detached itself from the door. There might be some plastic damage, which could be repaired. The only way to see what is happening is to remove the top cover and eject the tape.
Nov 28, 2013 | Sony DSR-25 Mini DV VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Apr 08, 2010 | Sony EVC100 Hi8 VCR
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
193 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
