The speakers won't work and the volume control does nothing, even though when I go into the control panel and play the RealTek Audio stuff, it plays. That's the only sound I can get to work and all drivers are functioning correctly.
if your computer came with
a motherboard disc the sound drivers could be on it click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers click start control panel
sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settingsthere also click start control panel
sounds and audio devices select advanced there might be a tick in the mute box
untick it if his does not fix the
problem click start control panel
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume iconsystem select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check: the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer: if you dont have a motherboard disk you will need to download the sound drivers
Update your embedded sound from
Realtek to the latest AC'97 codec.
game controllers you might see a yellow question mark? Right click to reinstall
drivers or you can download the drivers
Realtek AC'97 Drivers &
Applications. The package includes: Driver/Application Setup Program; RtlRack
for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager.
DirectX 8 is required to enable advanced features.
If you are having problems with you sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
if you are having problems with your sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps or you could download
1: check the speaker wire. it should connect to a green port at the back of the computer. 2. In control panel open realtek audio device manager. it will tell you where its connected 3. try to configure the speaker from audio device manager on the system tray volume icon still doesnt work then uninstall the driver for sound card from device manger restart the computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or you might have to uninstall then reinstall either the driver or the sound devices control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustmentsthere or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver hope this helps
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
1. Open Control Panel > Sounds and Audio Devices.
2. Click 'Advanced' Button near the bottom.
3. Select proper sound system (Quadrophonic or surround sound) according to your speaker system. 4. Click 'OK'.
5. Also check volume.
6. Double-click Volume icon in taskbar.
7. Click Options > Properties (From menu) and select 'Playback'.
8. Select all Audio components.
9. Click 'OK'
10. Increase all the volumes.
Now try playing a sound. Good Luck!
What I suggest to you is go control panel click sounds and audio devices the speaker volume is gray out. Go on line realtek.com choose ac97 audio driver and download. install the driver and make sure that the speaker are all plugin before start playing music. email me [email protected], if this procedure didn't work for you.
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
