SOURCE: Change MP to 12
If shooting RAW set the resolution to 4256 when using the raw converter. If shooting JPG's set the 4th setting on the function menu to 4256.
SOURCE: error msg fuji s2
couple of things:
I take it that "Err" shows on the display ? This can be caused by a number of things, including the aperture ring on the lense being in the wrong position. Make sure its set to the orange number. The 'err' message isnt generally shown for a power problem. If you have a DC power lead, attach that and see if you can get the camera to work.
Batteries are a nightmare for the S2.
Firstly, if looking for rechargeable AA's, you need at least 2300mAh. Maplin are doing a good deal till the end of the month on them; http://www.maplin.co.uk/Module.aspx?ModuleNo=46414
If you have the small lithium batteries in, then take them out. If the camera senses that they are in there, it will try and use them -even if they are depleted.You can replace them with CR123a batteries, but unless you want to use the on-camera flash, I wouldnt bother. DONT BUY RECHARGEABLE CR123A s !! They do not have anywhere near enough power.
Summary;
Check aperture ring
remove/replace CR123a (High quality replacement)
Use high power AA's
let us know if this works
SOURCE: my fuji FinePix S2 Pro is processing images with a
Could be a white balance setting or you've accidentally engaged a digital filter. You could try a camera reset. Go into the setup menu and scroll to "reset". This will take you back to the default settings.
SOURCE: Fuji FinePix S2 Pro
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
