Question about Lands Phones
Need auto hang up
I need to find a home phone system that when my in laws forget to hang up a handset the system will auto disconnect after a period of inactivity so I don't have to stress when I call them and there phone is off the hook for two days and my wife is freaking out and we have to make a 300 mile drive overnight to check on them
    Champion:
  • 211 Answers
Avaya IPOffice can do it. You can add another independent phone in your inlaws home and by using DSL connect to their home and start a coffee machine if desired. Page them would be more appropriate though :)
Call 1-866-980-ivds. They are an Avaya Business Partner
Posted on Jun 25, 2009
Panasonic phone has duplicate handset numbers
Panasonic is famous for one handset not working. They like you to use their free repair, because then they can get the encryption code your phone system is using.
Local law enforcement frequently requires access to a suspect's stored phone numbers and/or conversations. So this makes it a bit easier for them to get that information. They just get the code from Panasonic.
I recommend that people just forget about the defective handset and store it somewhere.
Jan 20, 2014 | Panasonic KX TGA641 Cordless Phone
I forget my security code.I can't format my handset.My handset model is nokia 3110c.Please help me.My set isn't instal application
it was tested by me in nokia classic series ,3110c ,3500c ,5130c etc blinking or hang only in NOKIA logo or handshake...no need to go to nokia care or cellphone shop to spend money..just do this tricks...
long press the *, 3, send, and power on...try up to 5 times and see for the result....
i hope it will help you..thanks for trusting fixya
Apr 13, 2011 | Nokia 3110 Cellular Phone
I have a cs6328-3 model vtech digital ans system. It is only 1month since purchase. the three handsets are the original handsets and i have no additional handsets that were added. Error: out of range / no...
Periodically, while using my Vtech Model CS6328-3 phone, it becomes virtually impossible to hear the other party - interestingly, it affects other non-cordless phones in the home at the same time. Just like that, the volume may come back. The person on the other end sometimes has the same proble hearing me - but not always. Have switched back to a previous Panasonic phone system in the interim, no problems. Seems to be the Vtech system. Any thoughts?
Mar 20, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
How can i format my phone memory
You can't format phone memory You can forma(flash) the entire phone(actually formatting means deleting the entire system file it's also called as flashing).
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
Thank you
Don't forget to rate
Jan 17, 2011 | Nokia E52 Smartphone
My nokia n72 has a problem when ever i on it during the booting period it hangs and sometimes it will work and during the period i am making use of it, it will hang please i need help
Dear customer miraclebenso
I will very happy to help you please follow those steps
1)You just switch off your handset first
2)Press *star button- 3 button-calling button and on/off key at a once times but don't put out your fingers until the phone star for formating. Two persons may do better this so take help from any other person.
3) Your handset will restart automatically.
It will erase your all data of phone memory ( CONTACT , IMAGE, RING tone ) It will work 100/ or you should to flash your mobile phone by FLASHING software. There are many softwares in the market for example JAF, UFS and HWK . If you are not a trained mobile technician then you should to contact your nearest NOKIA care center. Thank you RON Rank : GURU
Jan 10, 2011 | Nokia N72 Cellular Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
Time and date
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
Change the time
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
1,733 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
