Question about Timex T41091 Expedition Watch
Please provide directions for setting the alarm. Thanks!
  • 1 more comment
  • wgdeavens Jun 24, 2009
    Please identify the appropriate button. There are 4 buttons on each side. The lower right one illuminates the face. I do not know which one accesses the menu you mentioned. Please advise.
    There are 4 buttons, two on each side. The lower right button illumiknates the face. Which one are you identifying? Please be more explicit about what I should do to access the menu. Thanks!
  • wgdeavens Jun 25, 2009
    I will follow the directions and let you know if I need further assistance.
    Brigadier General:
  • 3,614 Answers
HI there,
Setting Alarm
  1. Using the MODE button, go to Alarm mode. The display will say ALARM for a moment, then that will be replaced by an alarm time. At the top, it will say T1 or T2, followed either by some dashes, or a month and date. In the middle, it will show a time, and at the bottom it will give the alarm number. You can set up to 5 alarms on this watch. To choose between the 5 alarms, press the RECALL button.
  2. To set the alarm you have selected, press & release the SET button. T1 (or T2) begins to flash. This tells the watch whether this alarm should go off according to the time you have set in your 1st time zone, or according to the time in the 2nd time zone. Press the RECALL button to choose between T1 or T2.
  3. Press the START/STOP (lower right button on the face) button and the AM or PM will begin flashing. Choose whether you want the alarm to go off in AM or PM by pressing the RECALL button.
  4. Press the START/STOP button and the hours will begin flashing. Choose the hour by pressing the RECALL button. If you pass the hour you want, you can back up by pressing the STOP/RESET button (the lower left button on the face).
  5. Press the START/STOP button and the minutes will begin flashing. Choose the hour by pressing the RECALL button. If you pass the minute you want, you can back up by pressing the STOP/RESET button.
  6. Press the START/STOP and the months position will begin flashing. If you want the alarm to go off as a daily alarm, then leave this as dashes. If you want the alarm to go off as an anniversary (yearly) alarm, then press the RECALL button to set the month. If you pass the month you want, you can back up by pressing the STOP/RESET button.
  7. Press the START/STOP and the days position will begin flashing. If you want the alarm to go off as a daily alarm, then leave this as dashes. If you want the alarm to go off as an anniversary (yearly) alarm, or as a once-a-month alarm, then press the RECALL button to set the date. If you pass the day you want, you can back up by pressing the STOP/RESET button.
  8. When everything is set the way you want it, you may get out of setting mode and lock your settings in by pressing the SET button.
Arming and Disarming the Alarm When you are in ALARM mode (but not in setting mode) you may turn your alarm on or off by pressing & releasing the START/STOP button. A little symbol that looks like a clock will appear above the M in AM or PM when the alarm is armed. If it is disarmed, that symbol will not be there. If that symbol is showing when you are in regular time mode, then at least one of your 5 alarms is armed. You can go to alarm mode and use the RECALL button to scroll through all 5 alarms to see which ones are armed.
Hope this initial info helps.
Let me know for further clarifications
Posted on Jun 24, 2009
    President:
  • 1,383 Answers
Just press button and enter in alarm menu then set timer to oyur time when you want to alarm.
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
Jacques Lemans GU175 - how to set alarm?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all JL watch manuals.Rate me, please
Mar 15, 2010 | Jacques Lemans Geneva Alarm Black Leather...
Setting alarm in F5015D F1 series watch
ypu can get a set of instructions by going to their web site (www.jacqueslemans.com).
On the left yu will see a menu, click on "instructions/catalogues" and you can download the instructions for your watch.
Feb 02, 2010 | Jacques Lemans F1 Analog Digital Watch
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Directions to set watch
She clearly states that she lost her instructions to SET THE TIME.
Why didn't you ask her where you could send it.
Nov 22, 2008 | Timex Expedition 84601 Wristwatch
Timex 1440 Sports Aggressor: how to set time and alarm
i just bougth a 30 lap shock/resistant timex ironman triathlon, and i need to know how to use it... i have no instructions thanks
Jan 23, 2008 | Timex 1440 Sports Aggressor 56014 Wrist...
Timex T41091 Expedition Watch Logo
189 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
