Question about Honda Electrical Supplies
New generator stored in carport does not have any starting spark. It is electronic ignition. It is a honda GX-160 . I had stored it properly: drained all fuel out. Prior to storing for 2 years it worked great. I'm not getting any spark at all.
  • jackb69 Jun 24, 2009
    I already tried the spark plug swap, no help. I even had to change the pull cord on the generator, as it broke, because I had pulled so many mtimes trying to fire off the engine.
    I have a Honda Generator that has been stored in my carport for 2 years. It will not fire over. It has good fuel, I changed the spark plug & it still has no spark. It has electronic ignition (model # GX-160) Before I stored it, it worked fine.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
The spark plug may be bad or the motor is flooded
Posted on Jun 24, 2009
    President:
  • 392 Answers
Change the spark plug with a new one with the same heat range.
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jun 24, 2009
    then u need to service the motor...
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
Erratic and weak spark
IF that is a small engine and has a magneto. You need to check the gap between the coil and the magnet on the flywheel. The easiest way to judge that gap is with a business card. If it fits between the two parts without effort, then it is too much gap.
Mar 31, 2015 | 5.5 HP GX160 Engine
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Honda GX 240 engine has spark, new carb; won't fire. what do I do?
remove the muffler and try it there is a screen inside the muffler that get carbon build up if it runs with out the muffler pry it open and clean it
May 24, 2012 | Garden
Brand new Honda Generator 2000i will not start. uhhg
Hi and welcome to FixYa I am Kelly.
Things that must be verified.
1. Fuel selector: ON
2. Start run sw: ON
3. Oil Level : Full
4. Choke selector FULL ON for no more than 2 pulls initially The half choke then off
5. Spark at the Spark Plug YES? NO?
a. No spark suspect low oil level sensor is grounding the ignition either due to low oil level or it just is not working properly.
After doing all of the above...
Spark Plug WET or DRY? Dry and still won't start check fuel supply. If you use the choke with the start run switch in the off position the spark plug should get WET. Spark plug does not get wet... with choke on and ignition off. Fuel supply problem.
At this point I suspect either the Oil Level is incorrect or... that the FUEL SELECTOR is OFF.
If you need more help just respond here and we can press on.
Thanks for choosing FixYa
Kelly
Sep 02, 2010 | Honda Electrical Supplies
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Mar 22, 2009 | Electrical Supplies
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Electrical Supplies Logo
55 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
