Question about Maytag Neptune FAV6800AW Top Load Washer
What is Lr error code - Maytag Neptune FAV6800AW Top Load Washer
  • 335 Answers
I’ll post this in reference to Troubleshooting an Lr error code associated to the FAV6800AW/FAV9800AW.
Lr = Locked Rotor error “”Locked Rotor: The machine has repeatedly tried to turn the motor””. This could be caused by faulty Motor Controller, Motor, Control Board or issues in communication of the Control Board to the Motor Controller/Motor via the wiring harness. Here are a couple of links to support troubleshooting efforts; Service Manual for reference. Sears Parts Direct for parts reference.
I’m an owner like you and I worked vai e-mail a while back with an owner that was experiencing a constant “Lr” error code on their FAV6800AW. That person ended up replacing the Motor Controller after replacing the motor that did not fix the issue. You could try the Motor Control Board Output Test on page 15 and others checks on page 16 of the SM.
Unfortunately the SM gives very little support in troubleshooting this issue. If you decide to troubleshoot first pull the plug on the 120VAC to the machine. You could try reseating the plug on the motor and the plugs going into the Motor Controller. This could be a hard one to troubleshoot without a known good Motor Controller, Motor and Control Board to substitute. If you are a DIY’er and have an DVM you could try the troubleshooting steps on page 15&16 of the SM.
If it were my issue and the SM troubleshooting steps did not help fault isolate the failed component I would pick up a Motor Controller from ebay (90 day warranty type) and try that first with my fingers crossed, not the way I like to troubleshoot. The Motor and Control Board are under warranty by Maytag for 5 years from DOP. I believe the Motor Control Board is under warranty for only 2 years. Maytag Customer Service contact info is at the back of the SM. Good Luck.
Posted on Jun 24, 2009
May Tag Neptune Washer error code LR
You can google this question along with the brand and the model # to get the answer.
Aug 02, 2015 | Maytag Washing Machines
Dell E1505 memory test march LR failed error code 2000 0123
try removing 1 memory stick at a time and see if it boots. hope this helps
Apr 05, 2013 | Dell Inspiron Computers & Internet
Error codeLr?
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Feb 14, 2012 | Maytag Washing Machines
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
313 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
