Question about Bosch Axxis WFL 2060 Front Load Washer
Moved to new home hooked everything up washer will not fill
Checked water lines they work, all lights work. push start and I hear the motor start to hum, but then no water is pumping into washer and motor shuts off... any Ideas? Please Help
  • 25 Answers
Ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Posted on Jun 24, 2009
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Bathtub jets will not start
Our reset for the jets were hidden in the master closet behind the tub. We also found another access point to the tubs inner workings in the same place. Also, make sure they open all the air intakes and the tub is filled prior to testing. On ours if water is not above a certain level it won't come on.
Aug 02, 2009 | Home
Washer fills with water then stops
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Windshield sprayer won't work
when you turn on the sprayer you should hear a pump motor running, try this with the engine off and key on so u can hear better. if u dont hear the pump then check the fuse if its ok then u will need a new windshield washer pump. if the pump is running when u activate it check for a leak in the lines. if you hold the washer button down long enough and the pump is running then you will see washerfluid leaking from somewhare. have hood raised when doing this so you can see better.
Dec 18, 2008 | 2006 Ford Mustang
I recently moved to a new city. When my washer was hooked up, it wouldn't not work. It fills up with water and stops. Won't do anything else. Need help
  • check the wires that connect to the motor, they may have worked loose during the move.
  • also check the lid switch and make sure it is clicking when you open and close the lid.
Jun 28, 2008 | Washing Machines
Water Trickles in When Filling
check the sreens in the hot and cold water valves on the machine make sure there not plugged with rust
Mar 06, 2008 | Roper RAS8445KQ Top Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
202 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
