SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
SOURCE: The Samsung scx 4521 printer JAM
ithink it is a hard were pr oblem we should clean our printer time by time, there is many dust inside, they can make disattacment between sencer and parts ,so we get this information. open printer and also if u open drom and other part open , then blow air by air blower machin e.we solve more than 80% thise type case in our lab .
SOURCE: My printer Samsung SCX-4521 F is not picking up
turn on/off, unplug, plug in, should reset configs.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper. take all the paper out, put half as much back in.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
SOURCE: My Samsung scx-4521 will not copy or scan
hello this is a problem with your scanner unit. check it out. replace scanner cable.
