Question about Hitachi 42HDM12 42 in. Plasma Television
Hitachi 42hdm12a hdmi mode keeps searching, but no picture
Went to menu. Said main signal source, -no signal
main signal format - shows auto
pip video source- no signal
won't let me go into the menu.
help!
2 Suggested Answers
  • 105 Answers
SOURCE: when connecting dvd to hitachi 42hdm12a, screen
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Posted on Jun 24, 2009
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Show picture but no sound. went to the menu button to look for the audio but not successful.
Your audio source needs to match the signal you are receiving. On the menu go to audio and then setup My source is set to HDMI (like my video). Within that selection you have the choice of analog, digital or auto. Auto should work for all signals. Analog will not give you sound if you have a digital signal (I found out by accident).
Oct 10, 2009 | Toshiba 19AV600U LCD TV
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
7.
Jun 24, 2009 | Hitachi 42HDM12 42 in. Plasma Television
Image too big for screen
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
PICTURE IN PICTURE (PIP)
Samsung say;
The feature only works on the AV/PC channels and not on a single tuner (digital or analogue) and only if your AV source (Sky Box/Freeview/Dvd ect.) is connected to the TV by way of the RGB or HDMI connections.
Good Luck
Nov 06, 2007 | Televison & Video
PIP trouble
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Sep 25, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Foot note to issue
If the source to the PIP input is a color signal then the PIP display will be color. PIP sets have two video sources one goes to the main screen while the other goes to the PIP. it all depends on what the format of the signal is being sent to each input. This is quite normal.
Jun 29, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Apr 08, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
222 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
