Question about Sony STR-DA90ESG
SOny DA90esg sound distord like it have a cold ? any ideas
Turn on fine tuner pick up radio station good -but sound out put is like it had a head cold -no bass at all and hight very static also have to turn up volume very hight over 1/2 to get sound to speakers .thanks
    President:
  • Sony Master
  • 1,114 Answers
Check your wiring. Sounds like your "out of phase" The easiest way to tell if this is the problem is to adjust the balance from left to right. all the way on either side should sound good, then move to the middle and it sounds dead. That's it. Find your speaker wire that has the + and the - reversed and switch. If this is not the fix, post a comment and I can help you dig some more. Hope this helps
Posted on Jun 24, 2009
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
Digital frequency for tv sound on Emerson RP6248
You can't pick up the sound on this radio any more. With the new digital system, sound is digital as well and can only be picked up by a digital tuner. All this radio is good for now is regular radio broadcasting.
Jun 15, 2009 | Emerson RP6248 AM/FM/TV Radio
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
Don't receive hardly any FM stations
Well I would consult your manual.  Home receivers usually dont have the same amplification factors that a mobile unit does as far as sensitivity.  But for best results make sure that you are using the supplied antenna, and put aluminum foil over it.  This will help amplify the signal.  Also consult the manual as to weather there is a setting for DX or Local.  If there is, make sure that it is not set to local.
Jan 03, 2009 | Sony STR-DA90ESG
Direct tuning
Unfortunately, according to the manual you can not directly tune a station.
Dowload the manual here:
http://esupport.sony.com/US/perl/model-find.pl?mdl=STR-DA90ESG
and go to page 50.
Oct 23, 2008 | Sony STR-DA90ESG
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Sony STR-DA90ESG Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
