Question about Plumbing
My pump is buzzing but not turning i Just hooked it up. i was told it was working last year. is it burnt or corroded and frozen.what do i do. can i rebuild it? nordic hot tub crown ii
  • 76 Answers
YES IT CAN BE REBUILT TAKE IT APART AND CLEAN EVERYTHING AND FREE UP ALL MOVIG PARTS LIKE THE BRUSHES THEN LOOK FOR ANY BURNT WINDINGS IF ALL IS WELL TRY IT OUT OH AND MAKE SURE THE BEARINGS ARE NICE AND SMOOTH
Posted on Jun 24, 2009
Emerson 1081 pool motor
There are several problems that will cause this. It be will more than likely be a front pump seal has leaked and the bearing has rusted up preventing the motor from turning or the start capacitor has failed . have the capacitor checked first unless you have burnt out the field wires of the motor it will be repairable.
Jun 09, 2013 | Pool & Spa
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Windshield washer pump fpr a 2006 chevy impala is there a fuse that could be bad ?
Yes, you could check for a fuse burnt out, but generally if the windshield washer pump doesn't buzz or turn so you can hear it, it means that in this weather, it is frozen up or burnt out. Usually it's just frozen with summer formulatioin of windshield wiper fluid which freezes at 32 deg. F.
Try to warm up the car in a heated garage to see if the windshield wiper fluid becomes unfrozen.
And, try to flush out the old fluid when you get it the pump free of ice, and install -20 deg. F or better wiper fluid.
Good luck on this repair.
Dec 18, 2010 | Chevrolet Impala Cars & Trucks
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
My 97 GMC sierra doesn't have a fuel rail or a valve to hook up fuel gage. I was told to hook up at fuel filter. will this work
It should have a valve. However, as I have a 96 I can tell you to start with dropping the tank and replacing the pump, I have to do this every 4 to 5 years on mine. NAPA is the best choice and longest lasting part its been about 4 years on my last change and counting...;) Everyone I know who has this truck has to endure this problem.
Oct 27, 2010 | 1997 GMC Sierra
Have carrier heat pump that buzzes
What exactly does it do? If it buzz and don't turn a starting capacitor will not help, this is an indiction of a shorted motor.
Jul 02, 2009 | Carrier 38CKC036 Air Conditioner
SENDING UNIT ???????
most of fuel pumps were in tank, wire corrodes is harness under right front seat floor pan to tank
if fuel pump buzz is heard and car runs and when it doesnt run you cant hear the fuel pump try
turn ignition off wait 10 seconds
turn ignition to on position to (prime or hear pump buzz)
no buzz fuel pump not working check fuel pump relay(swap with another) and try again?
you could use test light to pump wiring and make sure your getting power to pump on this prime test no power relay or wiring problem.
power at pump, but no buzz fuel pump faulty
Jul 01, 2009 | 1997 Isuzu Rodeo
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Buzz sound when i hook my laptop up
How many years have you had this laptop? Sad to say, if it's many years, time to replace as that would be cheaper.
Apr 29, 2017 | Sony STR-DE595 Receiver
Plumbing Logo
264 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
