Question about Pentair MINIMAX NT TSI IGNITER
I have a Pentair MiniMax NT heater about three years old. The unit is making a loud "popping" sound when heating. I think its the heat exchanger from what I am hearing. Can a heat exchanger be cleaned out? Or does it need to be replaced?? Thanks a million Greg
    Problem Solver:
  • 7 Answers
The heat exchanger can be reamed or replaced but it is quite a job; replacing the heat exchanger is very expensive and time consuming. unless your pool chemicals are extremely out of balance, most especially low ph from using tablet chlorine or too much acid the heat exchanger should not have worn out this quickly. the best solution if you do not have a pool serviceman is to call Leslies Pool Supply or a trained Pentair service tech. It may be worth the service call to have the problem diagnosed by a pro.
Posted on Jun 25, 2009
I have a 8 year old pentair minimax 200ch that does not start but pilot liights up
all these heaters have safety features that must test 'ok' before they will light. the first place to start is the pressure switch. if it doesnt sense water flow, you will not have heat
Jun 28, 2014 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
There's water leaking from side of heater
this is 100% broken heat exchanger its the coils inside of heater that heats the water this usually happines from really old age or because your climate temperature is below freezing and broke the coils, i see it all the time in winter season, best way to prevent this is to run your heater for fifteen minutes every month and make sure pool equipment runs all day everyday when its really cold out you can start running system normaly after your outside temp is warmer. its better to get a new heater when this happines heat exchanger is hard to install for most tech's pretty much have to take whole top part of heater off and is also expensive part
Jan 27, 2011 | Pentair Minimax NT Heater
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Mar 20, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair MINIMAX NT TSI IGNITER Logo
363 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
