Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
20 hp briggs and stratton revs up and down
I can start my mower and thr governor wants to make the engine rev up and down quickly and i can cut most of my yard. it has new air filter, fuel filter, fuel pump and pilse hose for the valve to fuel pump. Also new gas can anyone help me???????????
  • Anonymous Mar 26, 2014
    someone changed the governor setting on my 21.5 hp ohv intec engine. I need help to set it so it doesn't rev at 10,000 rpm!
  • 109 Answers
Lower throttle and if that doesnt solve it check the governor might be broke
Posted on Jun 24, 2009
    Problem Solver:
  • 10 Answers
The govenor gear shaft at the cam gear has come lose in the block. the only fix is a new block , short block or engine
Posted on Jul 24, 2009
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
How do i ajust the governor on a 22 hp briggs
be carefull this one is best left to pros if you over rev you will loose a rod
Oct 08, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do i ajust the governor 22 hp briggs
be carefull this one is best left to the pros if you over rev youll loose a rod
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
98 model craftsman,17.5 hp,redone carb,all linkage good,not sucking air,idles great,won,t rev up,govenor broke inside engine?thanx,confused
Probably not the governor, most likely it is in the carburetor. The main or the high speed jet circuit is likely obstructed.
Jul 22, 2011 | Briggs & Stratton Garden
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
10 hp briggs runs at high speed, govenor don't seem to be working
One possible cause for this problem is debris,sticking,or frozen linkage between the governor and the throttle butterfly. Depending on the make and model of your engine it will either be a mechanical governor that has a arm that goes down into the case or a air vane governor that is behind the recoil shroud of the engine. Move all the linkage that connects between the governor and throttle and speed lever to make sure it doesn't bind or sticks. If it does pray a little silicone or wd 40 spray on it to help reduce friction. Also on air vane governors they can become stuck from debris that inhibits it from moving make sure there is nothing in the way of the governor. If all of the linkage is working properly and you still have the issue try adjusting the the fuel mix screws and the high rev. settings on the throttle lever (if equip.).
Jan 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
2,534 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
