Question about Sony DVP-FX700 Portable DVD Player
Disc error displayed on screen after display screen goes out- Open cover and di
Disc error is displayed on screen after blue lit display area goes out=open cover and disc is stopped. the mpeg mode works however for photos on cd. Thanks for your help!
  • Anonymous Mar 31, 2008
    havent tried anything to fix it.......i try to play a brand new movie and it wont play because it says there is no disc
  • gettleman Jul 26, 2008
    Will not play DVD. Disc error messageon screen. LCD only turns off and on. No menu.
Check the lens
Posted on Mar 08, 2008
Screen goes blank
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
Mar 18, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My RTI m2(?) fell off the table to the floor. The black cover dislodged and the screen also dislodged. It was still lit. When I replaced the screen the icons were lit with a pink band across the bottom of...
Sorry this remote can't be repair it is garbage,because the small display LCD screen panel it have mircro cracks and fractures in them and leaking chemicals radiation that why u able pink chemicals band across the the small display LCD screen panel.It time to buy another remote.
Sep 06, 2011 | Rti Technologies Rti T1 Remote Control
My dlink is set up and it shows on my wireless network but when i connect there is no internet comng through it just goes to a can not display this screen at this time page
Check the WAN light on the router -- if it is not lit, then your router is not connected correctly to your cable-modem or DSL-modem.
Start Internet Explorer, and access the web-server "built-in" to the router. Access the "settings" page, and check the "WAN" settings, to ensure that the router has received an IP-address from your Internet Service Provider.
Sep 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a sony minidisc e10 and on the display, some of the lit areas are dimmer than others, Is there anything I can do to correct this?
The display is on it's last leg, the only thing you can do is replace it with a new display if you can find one.
Mar 12, 2010 | Sony MDS-E10 Mini Disc Player
There is a thin white verticle line on the monitor.
Open this link and make it full-screen. Watch the screen for 20 seconds or so to see if the line of lit (white) pixels remain.
If this line remains during this, and even when the the computer is first starting up, it is most likely a row of "lit" pixels caused by a faulty connection or circuit inside the display.
While you can sometimes rub the area of the screen near a single lit pixel, an entire line of them usually denotes a more complex problem that can only be fixed by having parts replaced by a technician
Note: Be sure all of your cable connections are securely fitted, and that the line is there no matter what is displayed on the display (especially at the boot screen before Windows loads).
Sep 20, 2009 | Samsung Computers & Internet
DELL VOSTRO Display goes blank after it is more(than halfway open
You should be able to remove the LCD hingecover and reeseat the video cable. But hte issue may be a damaged cable going thru the hinge assembly which would require a replacement LCD.http://support.dell.com/support/edocs/systems/vos1500/en/sm/display.htm#wp1179838
Jun 04, 2009 | Dell Vostro 1500 Notebook
Blue screen on main display
Hi. this reoccurring error is due to programing and hardware failure. you will need to remove the battery for 5 minute. if the error continues after you re insert the battery, this will confirm this fault in the hardware. your phone will require repair in this case.
May 22, 2009 | Nokia 6085 Cellular Phone
Upon power up error code CH is displayed , with second drawer
The steady CH indicates an open right side door. Being that the tray 2 is lit up it could be the side door for the second tray and not the one on the main body. Pull tray 1 and 2 out completely and make sure there is no paper stuck in the machine behind where the tray goes. Double check that both side doors are closing properly and that nothing is broken or missing in that area.
Mar 21, 2009 | Sharp AR-5316 Advanced Digital Imager...
Back cover open
There is a sensor on the back of the fax machine inside the back door area. There you should see a few plastic chutes that may have a small movable plastic lever called a actuator. This actuatoer may have come out of its pivot points. The parts usually can be snapped back into place. Check by moving the parts and see if the error message goes off. You must move the chute open or closed while looking at the lcd display. This may narrow down your issue.
Feb 13, 2009 | Brother IntelliFax-2820 Laser Fax
Sony DVP-FX700 Portable DVD Player Logo
196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
