Question about Vehicle Parts & Accessories
MarkX alarm i got a markX , got push start feature ,immobillizer, got a remote (keyless entry) .i want to place a alarm for it , is it possible ?? need help
    Novelist:
  • 131 Answers
Being you have alot of alarm fetures installed already, try a valet alarm, that alarm should help you out... and it will work with all your systems, if not that one then there is a 3 wire alarm that you can google search that you can install it is only an alarm, all the other features you have already installed would need their own key fobs.. but if you want to use one key fob, try the VALET alarm system cause most you can reprogram the fob to do the remote start, and connect it to the immobillizer no problem... but i would still take it to a shop that specializes in alarms cause if you do not know what you are doing, then you could lock up the starter, or not be able to start the car if you cross the wrong wires... but to answer the other question YES it is possible...
Posted on Jun 24, 2009
How do i find out if vehicle has remote start feature ? all functions on key fob work except engine crank even park lights flash indicating remote start feature . maybe a fuse blown or not in place.
How to check if your GM car is equipped with factory keyless ...
blog.remotesandkeys.com/.../How-to-check-if-your-GM-car-is-equipped...
Aug 25, 2011 - Many, but not all GM vehicles, are equipped with factory keyless entry. ... If not, and you want to have remote keyless entry, go to an alarm shop or Best .... Your other option is to locate the aftermarket receiver under the dash and ... start but need programmed or how can i check if i have remote start installed.
Remote Start ' Vehicle Features ' Official Ford Owner Site
owner.ford.com/.../vehicle-features/.../remote-start-...
Ford Motor CompanyIf your vehicle has automatic climate control, you can configure it to begin operating when you remote start your vehicle. A manual climate control system will run ...
Factory Remote Start Installed? - Chevrolet Forum - Chevy ..
Jan 14, 2016 | Cars & Trucks
Why are the parking lights staying on when ignition is off
sounds like you need the remote either a new battery or it needs re syncing with your vehicle , follow this link for advice
Subaru Keyless Entry Security Alarm Immobilizer Key Remote Start...
Jun 23, 2014 | 2004 Subaru Outback
I want to add a keyless entry to my 1996 Ford Explorer XLT 2WD 4.0L and also a remote start. It does not have any type of remote for the vehicle right now I.E. alarm system. Is it possible to do a remote...
This is possible with almost any vehicle, especially ones with power locks. I installed keyless entry on someone car before on my own. Took about 3 hours or just take it to a local shop. Its a pretty easy install for anyone who is mechanically inclined.
May 06, 2011 | 1996 Ford Explorer
2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Aug 13, 2009 | 2001 Subaru Impreza
Keyless entry alarm sounds off at a set time, How
If you have children that play with the remote itself, it's very possible that they have pressed a certain code and set the alarm to do that. My 18 month old loves to play with my keys... which was fine until my tahoe started cranking every 3 hours. When I took it to a mechanic, they determined he had pressed a key code to make it auto crank. They reset it and I haven't had a problem since. Hope this helps!
Jul 30, 2009 | 2008 Chevrolet Suburban
Ready remote Brand after market keyless entry remote start the Door lock /Unlock feature wont work when the button is pushed i can hear the unit beep but nothing happens at all all other features work...
that is because the push button pad is broken inside the remote box unit or either it is not making contact with the switch in the alarm remote. may need to replace the push button remote box.
Jul 25, 2009 | 1997 Ford F250 SuperCab
I just bought a 1994 Accord EX and it only came with one key, i notice that everything is powered. How can i get a set of keyless entry remotes without going to the dealer?
you can go to someplace like best buy or any audio store that sells and installs alarms and remote starts you will probably have to install a remote start to get the keyless entry feature.
Jul 14, 2009 | 1994 Honda Accord
Program factory remote keyless entry: 2003 Hyundai XG350
The procedures you list require the Hyundai Keyless Remote programming module, which you don't have. This module is proprietary - only Hyundai Dealerships have it. There is a 10 pin connector under the dash (next to the DLC - Data Link Connector) which is used to connect the Keyless Remote Programming Module. This module has two switch positions "Ready" and "SAVE". When the switch is place in the 'SAVE" position, that's when the keyless remotes are activated to send their 'codes' to the Electronic Time and Control System (ETACS). The module's switch is then set to "Ready" and the remote is tested to see if it works properly.
May 22, 2009 | Hyundai Motor 2003 XG350
Vehicle Parts & Accessories Logo
116 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
