Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
I have a campbell hausfeld iron force series 16 gallon compressor just replaced the belt cause it broke replaced with the high temp belt kit which includes a new pressure check valve and the problem now is that eveything seems to be working except it is not building any air pressure did check the drain petcock to see if it was open and that is not the problem and did check the relif valve that is not the problem either. any answers would aprechiate. thanks
    Sergeant:
    Champion:
  • 226 Answers
There is a tiny O-ring on the adj. knob you will need to replace it .hope this help's
Posted on Jun 24, 2009
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
My belt broke from my air compressor and i dont have any way to find the size of my old belt. i have a wl 650001aj compressor. can yall help me find a belt number so i can go to a automanufator to find...
The belt for your compressor is available in a kit from www.chpower.com the part number of the kit is WL015303SJ
Here is a picture of the kit, http://www.mastertoolrepair.com/images/WL015303SJ_medium.jpg
The reason the belt is sold in a kit form is because the belt will fail when the in-tank check valve fails or begins to leak pressure back into compressor. I do not believe that the belt is sold thru automotive supplier. It is too small. Here is the number stamped on the belt BT012100AV, it has 8 ribs and is about 15 inch length. Good luck
Oct 02, 2010 | Campbell Hausfeld 26 - Gallon Air...
My upright air compressor is getting tired and will no longer even run an orbital sander. Is ther a rebuild kit or something that can be replaced?
If your compressor is the oil-less type the cylinder and compression ring should be replaced when it takes an unusually  long time to fill tank. A rebuild kit is available thru www.chpower.com Good luck with your project.
Aug 10, 2010 | Campbell Hausfeld 5.0 Hp Cast Iron Air...
It does not compress air. I checked the belt tightness ok. Oil level is good.
Dear,
Please check the Valve assembly, Also check the Cylender and Piston for any scraches.
Regards
Ashfaq
Jul 13, 2010 | Campbell Hausfeld 5HP 20 Gallon Single...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
653 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
