Question about Sony KP-51WS500 51" Rear Projection Television
Adjusting red hue
When I turn my tv the picture looks more or less good but after a while the red comes on, and cannot adjust it. I tried to adjust the color but it doesn't work. I talk to a friend and he told me that it needed the part that adjust all the colors and picture. but I dont know exactly what part he was talking about, maybe you can help me.he sadi it goes in front you have to take off where the speakers go,
  • 2,336 Answers
You will find that info here but it could be a red CRT going bad and the adjustments might not work.
Hope it helps
Posted on Jun 24, 2009
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Pioneer SD-P55A5 shut off during use and wont advance past standby mode
This is a problem related to the hue controlls in the TV. It is quite common.
Fix: You can go into the TV settings and try adjusting the hue/tint there.
If adjusting settings does not work, request help from a technician to fix it for you since it will take adjusting the hue internally and if you do not do it correctly it can damage your television.
I hope this helps ya!
Jul 28, 2008 | Pioneer SD-P55A5K 55" Rear Projection...
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture qualiry
Try adjusting the setting of "hue" control of TV.It might be the wrong setting & the ratio of red hue could be more than the required one.
Apr 08, 2008 | Sony KP-53HS10 TV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KP-51WS500 51" Rear Projection Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
