Question about RCA RTD160 System
My rca digital dvd home theatre system won't read any discs, it will play radio , speakers work it just says "no disc" when i put one in
It is an older system .
SOURCE:
SOURCE: Disc Tray Won't Open
I have contacted Venturer Electronics Inc. (which have recently purchased RCA); they are in Toronto, Ontario. They suggested to perform a Manufacturer Reset (as follows); and if it works; system should power up [this means there was a glitch in the software]...(this usually happens when system is plugged into a power bar or surge protector) if not, contact them @ 1-800-721-4007. They honor the manufacturer's (RCA) 1 year warranty... with receipt.
To reset Unit:
Unplug Unit from AC power (other wires can stay connected)
Press the On/Standby button in front of Unit 15 times
Wait 30 minutes
Replug Unit to AC power
Press the On/Standby button to power up unit
Wait couple of minutes for unit to do its thing
**If unit works properly, then ensure not to plug unit into power bar or surge protector, keep plugged into wall.
**If unit will not power up properly, contact them for further instructions.
Hope this is helpful....
My Unit powered up wonderfully and is currenlty working like a charm.
Posted on Jan 24, 2008
jeremiahre
SOURCE: rca rtd 160 home theater
Power regulator burnt beyond recognition
Posted on Dec 09, 2008
CRTN
  • 716 Answers
SOURCE: decode region on dvd player
Try 7385652500070000+INFO When You Put In A Movie Let Me Know If It Works.
Posted on Jan 19, 2009
CaliBoy380
  • 11 Answers
SOURCE: We have a RTD259 RCA 5 disc home theatre system
Fist off, do you have Satelite TV or cable box? if so you need to run you audio wires from the audio out on those devices. If not from your TV should be audio out L&R to you audio input on your RTD259, now you may have a specific input for your TV, or you may not. If there is no specific inout for TV, there should be at least one AUX audio and video input open on your unit. Hope this helps, Cali
Posted on Jul 25, 2009
  • 31 Answers
SOURCE: Reads all as BAD DISC
my friend do you try to adjust the 2 potentiometer behind the dvd lens.?
there is 2 potentiometer and they can maybe be the problem.
but you have to be very delicated. and move only by milimeters. becouse if you move a lot maybe the unit no read more.
if you need help and you fell ready to do that ask to me.
Posted on Sep 19, 2009
My dvd is not playing . It can not read the disc
  • There may be DVD region limitations on your device, and you use a DVD disc that is not listed in your device.
  • It may also be the vendor of your brand DVD disc, including those that are not recommended.
  • The format of the files on your DVD disc, does not support.
  • Disc Optic is dirty / dusty. Clean it.
  • Disc is scratched.
  • Damage to the disc player.
Aug 28, 2015 | Sony DAV-DZ810 DVD Home Theatre System
Rca rs2767i
your cd player is broken check go and get a replacement
Apr 05, 2014 | Audio Players & Recorders
Panasonic DVD Home Theatre not reading
Make sure the tray is clean - no debris on tray If the disc is misaligned slightly it will spit it out
Make sure you are not putting them in upside down
and lastly find a new disk (not home made one) and see if this one works
Disks get damaged much easier than people realize\
If nothing works you have no choice but use a proffessional
Feb 06, 2012 | Audio Players & Recorders
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
I just bought a RCA rtd3131 home theater system. My husband trashed the manual and i can't get all the speakers to work when the cable is on. When the DVD is on all the speakers work but the sound is not...
If the cable tv has audio out jacks, or if you have a cable box with an optical audio cable, plug either the audio jacks into the RCA system or the optical audio cable, and the system should automatically simulate 5.1, through Dolby Pro Logic II. All speakers will not be at the same volume as they are simulating surround sound, not just playing the audio.
The TV will never have sound for the DVD as this system has no audio out puts. Realistically, most televisions have 10w speakers, and this system is 130w, so the TV speakers are useless in comparison.
Jun 28, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Home Theatre not reading DVD
put a cd to play if does replace the laser
Jun 15, 2009 | Televison & Video
I have a spectroniq pht-300x dvd home theatre that does not play
sometimes the reader is dirty and need to be cleanead you can sometimes do this by spraying compressed air from a can through the slot or you may have to open unit to access
Apr 27, 2009 | Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
I have a 50 inch viera plasma tv and just got a 1200 watt home theatre system product number SC-PT960 and have absolutely no idea how to hook it up properly. The instructions in the book are confusing me...
Assuming the TV is up and working on its own, here's the simplest approach:
Find the the Audio Out from the TV - either an optical connection or a dual RCA Cable (probably came with the TV) and connect that to an Input on the home theatre receiver. You'll need the right cable depending on whether RCA or Optical. That gets you Surround Sound into the Receiver.
Then, connect a cable from each speaker to the marked terminals on the back of the receiver -- Front L/R, Rear L/R, Center, Subwoofer, etc.
Check out your speaker connections by trying a radio station - should play through the front speakers OK. Then switch to the input you connected the TV into. Once you get the TV Audio playing through the receiver, you can go to your TV setup screen and turn off the internal speakers on the TV.
Hope this is enough to get you going.
Feb 18, 2018 | Panasonic 1200W 5.1-Channel XM-Ready Home...
Home Theatre System
well u can run direct tv to tv then the tvs master digital out to the rca digital in or anlog rca cable
Jan 27, 2008 | Audio Players & Recorders
RCA RTD160 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
