Question about Poulan Pro Chain Saw 46cc 20"
I have the same issue
My Craftsman 20" chain saw is model #360.352010. Runs great but when you put it to wood the chain slows to a stop. I cleaned it very well and still the same result. I also bought a new bar and chain to no avail. I am $80 in and wonder why I even bother. I wish my Sears service center was still open. Have you heard anything reguarding this?
    Brigadier General:
  • 4,088 Answers
Very likely it has oil on the interior of the clutch assembly. Wash out with carburetor cleaner from the auto parts store and blow out with compressed air. Hope that helps.
Posted on Jul 04, 2009
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
High trottle is not working it's full power
griffofarm
  • Rank: Master
  • Rating: 79%, 49 Votes
They have two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Nov 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What are the high and low carburetor settings on a poulan 3416 chainsaw?
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Jul 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Owners manual for Craftsman 20 in chain saw, needed
Go to searspartsdirect.com/partsdirect/index.action type in model no. and you should find parts list. You can also order parts manual from this site.
Apr 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
180 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
