Question about Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4)
I am borrowing my girlfriend's laptop with this card. It works on her home network, but whenever I attempt to connect to any other network, it doesn't work. It detects the wifi networks, but it never prompts me for a password, and refuses to connect. If I am in a free wifi area, it will again detect the wifi, but won't even bring up the usual start-up page necessary to connect. What am I doing wrong?
    Sergeant:
  • 268 Answers
You can only connect to networks that are not locked. If they are locked you will get a request to enter a username and pass. There is no way around this with out hacking (illegal). You may also be to far if you are unable to connect.
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Experienced techs waiting to help you with your needs.
Posted on Jun 24, 2009
Acer AspireOne safe mode setup
You are posting a docking station for a laptop. You need to make sure you Network Connections are good before attempting to use the dock with network.
More than likely you simply lost the drivers for the Network Interface Card,
Jun 04, 2013 | Computers & Internet
Please, my laptop screen just start showing white whenever I on it
Your lcd screen is going bad and needs to be replaced. It could be the video card but most likely the lcd screen is going bad. Try connecting another monitor to the laptop to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the white screen then your video card is ok and your lcd screen is bad . If the Borrowed monitor displays the same white screen then your video card inside the computer is bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 29, 2012 | HP Computers & Internet
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
Dell inspiron. "unidentified network" problem
Try disabling firewall software that must be preventing access to network. disable and reenable the lan card might also help
Feb 01, 2010 | Dell Inspiron 1501 Notebook
LCD screen is out of it so I have been hooking it up to my monitor. Also onboard ethernet card doesn't work. Can I replace it without replacing the motherboard? Computer was full of viruses so I wiped it,...
You need to download drivers for it?
I can give you a disk that can hook you up to the internet to download the drivers for it for free.
Please give me your address and send it to
mr.a.c.stopher@googlemail.com and put the subject as FixYa
Dec 30, 2009 | Computers & Internet
I have a d-link router. i can connect to my
The wireless card is configured for your D-Link at home.
You need to configure your laptop's wireless card for the wireless settings at work too (ie the SSID and encryption etc.). Contact the network manager at your work for the wireless configuration so you can configure the wireless card with these settings.
It maybe possible to setup different profiles on the laptop's wireless card, one for home and one for work so you can just click on the correct profile depending on your home or work location.
Dec 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
Can the Compaq Armada E500 go wireless?
hi,
any laptop has the capability to use wireless connection, if you connect to that laptop a compatible wireless card and install its drivers( the cd/dvd that comes with the wireless card)
to check if this card is ok or not try using it on some other laptop see if it works there and gets the networks
further Queries are welcome
Feb 18, 2009 | Compaq Armada E500 Notebook
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4) Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
