Question about Kyocera Switchback KX21 Cellular Phone
HAVING PROBLEM CHARGING PHONE - Kyocera Switchback KX21 Cellular Phone
Having trouble trying to change the language from spanish to english
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
CHANGE LANGUAGE:Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
Oct 25, 2012 | HTC Desire Cell Phone
Not charging
Well if your phone wasn't charging then probably the charger of your phone is having the problem, first of all you can try charging your phone using different charger. if you have the same issue after changing the charger then mostly the battery of your phone is dead.
Nov 05, 2011 | Nokia 5220 XpressMusic Cellular Phone
I downloaded latest win 7 drivers, rebooted PC, phone is recognized but not charging.
It denotes that USB charging is not supported by uour mobile phone.
If you are using the same socket in your mobile phone for charging whcih you are using for connecting your mobile to computer then there may be USB charging option available for your phone. If you are having separate charging Jack in your phone. Then USB charging option may not be possible. Please refer your mobile phone user manual to check whether the USB charging option is available or not.
I hope this is useful for you
Thanks
Mar 29, 2010 | Motorola Mobility E815
Charging problem nokia 1110
If the phone is not charging or charging is irregular, then problem is either battery , charger socket on phone, or charger itself.
If it does not charge at all, then it is either the battery or the charger.
If it does not hold charge then it is the battery.
If charging is erratical then it is either the charger connector/socket, or the ac charger.
The best thing to do is going to a phone shop, having the charger and the battery checked by the guys at the shop and replacing either the battery or the phone charger.
Mar 04, 2009 | Nokia 1600 Cellular Phone
Motorrokr E6 "Mobile not getting connected to PC"
USB cable is connected between PC and Mobile, Charging is happening. Modem drivers installed. Mobile phone is displayed having Sychronising, phone book, calendar, text message, multimedia studio. On this "initialisation....please wait" is displayed and after some time it displays "mobile not connected".
Jan 11, 2009 | Motorola Mobility ROKR E6 Smartphone
Phone not Charging
I'm having the same problem!...All three units not charging?
Aug 20, 2008 | Uniden Cordless Phone
Phone does not charge
  • check the charger by using it in ther phone
  • check the phone by using other charger
  • continue.......
Mar 30, 2008 | Nokia N70 Cellular Phone
Charging the phone
jry230 - the charging port needs to be resolder back on to the board.
ROBBIE1156 - have the charging port replaced on the phone.
Jan 18, 2008 | Motorola Mobility V551
Kyocera Switchback KX21 Cellular Phone Logo
24 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
