Question about HP Pavilion F1703 17" LCD Monitor
The monitor is green the color is not - HP Pavilion F1703 17" LCD Monitor
  • HP Master
  • 2,404 Answers
Check the pins out on the monitor and make sure they are straight, even and none of them are bent cause if the cable goes in with bent pins that would cause weird colors to come up on the screen.
Also make sure its connected to the video card properly as well and snug. If that still doesn't fix it, try another known working monitor on the computer and if that works then the lcd is bad on your original monitor, if you still get green even with a new monitor then its a problem with your video card.
Posted on Jul 04, 2009
  • 4 Answers
Make sure your plug is in correctly, both on the computer, and on the monitor. If it still doesn't work, you may have bent/broken pins, and may need to replace the cord.
Posted on Jun 24, 2009
When I turn on computer all I get is a totally green screen blinking gray. Cannot get on the computer
The monitor might be faulty ....do a monitor self test ...disconnect the datat cable from the monitor and turn it on ....there would be a color code , if the color code is ...
RED....GREEN....BLUE which might appear as RGB or the colors itself......then the monitor is ...if the color code is different then the monitor has to be replaced
Mar 14, 2013 | Acer America Acer Aspire AME600-UR368...
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
Dear Sir, My monitor is SAMSUNG 753DFX (17" White), my monitor green color problem (green color loss),pl. help me and give me solution. I am electronics familier. Thanking You, Arif
try to use windows color management scheme under properties of your graphic card setting. you can manually override the green red blue and gamma settings. In this way may be availing of desired result is possible.
Either way if you're familier with electronics, repair including possibility of shock hazard costs you more than the price of a new flat monitor.
Sep 07, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
Feb 05, 2009 | eMachines T6524 PC Desktop
17 crt monitor (BOKA)turned to green resolution
Try moving the VGA cord to the PC, faulty VGA cord displays such color problem.
Nov 27, 2008 | Computers & Internet
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
HP Pavilion F1703 17" LCD Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
