Question about Magellan RoadMate 700 GPS Receiver
Wont power up on car adpt. i ccecked power to end of adpt. with meter but unit wont power up
    Problem Solver:
  • 6 Answers
What was the dc voltage ????? sometimes like on my tomtom i have to hold down the switch a little bit longer to fire her up......
Posted on Jun 24, 2009
Cuts out restarts ok then cuts out after short run
Try changing the fuel filter or the gas pump if the filter doesn't work. Also have the ground wire to starter ccecked.
Dec 05, 2014 | Cars & Trucks
My lacie dvd burner is not powering on, all plugs have been checked and recheck
If it is not powering on and you have power working on the unit then the unit is bad. replace the unit. It just went bad if it is not powering on with it plugged in. Try using another cord if available to use or test it with a volt meter end to end plugged in. If it is powered by a USB port from the computer end. try restarting the computer and unplugging the computer from the power socket and push the button down on the power button on your computer. Then replug it in again and restart the computer then plug in the burner again and see if it starts up then. If not replace the burner unit it is bad.
Jan 22, 2011 | Computers & Internet
What network adpt. is in this computer
You can go to the control panel and then to system icon ..click system icon and go to device manager..here you'll see a list of all hardware installed in the computer...go donw thw list till you get to network adapter...click this and it will tell you what adapter is in the unit
Jan 18, 2011 | Compaq Evo D510 PC Desktop
How to put a switch in or do i need new one
By the question you asked I assume it wont power on. More than likely its not the switch . More likely its the power cord because it get most of the abuse. you will need a meter in any case to find out . If you don't have a meter you can pick one up for under $10 at any hardware section of most Dept store chains. A good investment. turn the meter to the omega symbol Looks like an upside down horseshoe with feet. touch the leads together meter should zero. place the probes across the end of the power cord plug. One on each tab. watch the meter and flip the switch while holding the plug and probes together. if the meter doesn't move the switch is probably ok. usually the cord plug or the strain relief going into the machine wares out but check the cord for cuts or unusual ware first. if you dont mind a few inches missing remove the bad area of cord and replace. to verify its the swich or not pull the unit apart and put the meter leads across the switch and toggle the switchthe meter should change from zero the some high number. Good luck have fun and learn !
Nov 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
WONT START REPLACE ENGINE CARBRATOR ADPT DO TO BOLT BROKEN OFF STILL WONT START
Check spark plug. remove the spark plug, clean it and test it. If it still doesn't start, take the spark plug out, and connect it to spark plug wire and try to crank the blower, and see if it makes a spark, if not you may need to replace the spark plug.
Nov 04, 2010 | Craftsman 225 Mph Electric Blower Vac
My dryer works but wont heat up anymore.It started doing this immediately after the power went out and resumed.
you may have a faulty heat unit of fuse on that heat unit, but i suspect that your problem may be improper power supply. check with volt meter at the wall plug. if good, check heater and fuse with ohm meter.
Mar 02, 2010 | Dryers
It wont turn on. theres power going into it but it wont turn on
TRY SWAPING THE RED AN YELLOW LEADS AS SOMETIMES (IE VW'S) YOU ARE USING THE CONSTANT MAIN FEED FOR THE MEMORY AND THE SWITCH FEED FOR THE POWER WHICH DEPENDANT ON THE CAR IS NOT ENOUGH TO POWER UP THE UNIT , ALSO THERE IS NORMALLY A FUSE IN THE BACK OF THE HEAD UNIT BEHIND WHERE THE LEAD PLUGS IN TRY PULLING IT OUT AND OR REPLACING IT, IF YOU HAVE A METER CHECK BOTH FEEDS ARE GETTING POWER, WORSE CASE UNIT DUFF OR IF SECOND HAND A PASSWORD MAY B IN IT
Dec 06, 2009 | Sony CDX-M630 CD Player
I have a Bissell Upright Proheat 2x and the dual power brushes wont rotate. I went to replace the drive belt and noticed the drive shaft does not turn when power is turned on. What shall I check next?
Is there a light that comes on when you "turn the power on." If there is no light, and the unit is plugged in, how do you know there is current going to the motor? Sounds like there might be a break in the cord. Examine the cord near the plug end to see if one of the internal wires is broken. If you cannot tell, then you need to try taking the unit apart where the cord enters the unit and testing continuity with a meter.
Aug 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My c840 latitude wnt boot with my previous power adpt you need to push f1 to start it
hello. That is because your computer measures the voltage from your power adapter. if the power is incorrect, then it will make you press f1 to adjust the computer to accept the power adapter. You need to get the correct adapter for the problem to go away. good luck !
Jan 22, 2009 | Computers & Internet
Magellan RoadMate 700 GPS Receiver Logo
65 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
