Question about Lasko 2530 Elite WindTower Fan
LASKO WINDTOWER I have a Lask windtowerModel 2515. It has started beeping from the control pad! It continues for several minutes after it has been unplugged! Any help? ANTIFREEZE
  • ANTIFREEZE Nov 08, 2007
    I had this fan for a couple of years and it was about 3' from the wall. I've cleaned the dust and crud out of it and it still beeps like a low battery! But I don't see a battery on the circuit board!
    Strange but challenging!
    Problem Solver:
  • 8 Answers
Is there some kind of timer going off? or does it have s sensor that can tell if something is too close to it? just some things to check.
Posted on Nov 08, 2007
How do I clean inner parts of Lasko ?
Take a small screw driver and file it down til it fits .push real hard to get them out.
Jul 18, 2014 | Lasko 2515 Tower Fan
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Lasko E20739 Fan
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
aka Gary C
Nov 10, 2008 | Lasko 2530 Elite WindTower Fan
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
May 11, 2007 | Lasko 2530 Elite WindTower Fan
Lasko 2530 Elite WindTower Fan Logo
346 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Shehu Pro
Shehu Pro
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
